Question about Nokia 6600
No application manager - Nokia 6600
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 55 Answers
Reset your phone:
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Posted on Dec 21, 2010
My phone keeps on displaying this massege:- "unfortunately, the process com.google.process.gapps has stopped." how can I solve it
Hi the gapps in the error refers to Google apps ENABLE THE DOWNLOAD MANAGER..step 1 : tap on apps ..step 2: tap ,& drag the application screen towards the right to access settings ,& then tap on settings icon 3: tap on more 4: tap on application manager under more tab. 5: now tap & drag the application manager screen towards left and access DISABLED application ( note if disabled tab is not available.go TO ALL TAB,) 6,: tap on download manager with Android icon. 7: tap on enable now Download manager is enabled ( disabled should B on screen ) ...8 restart you're device ...good luck
Jun 19, 2016 | Tablets & eReaders
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
Tip
Alternate method to access Application Recovery/Recovery Manager in HP PC
Scenario: Recovery manager or Application Recovery on your HP Desktop PC doesn't work or you are unable to access Application Recovery or Recovery manager.
Tip:
For Application Recovery:
1. Click start, my computer.
2. Open C: and Windows Folder.
3. Open SMINST folder within Windows folder.
4. Double click appinst.exe to open application recovery.
For Recovery Manager:
4. Double click restore7.exe to open Recovery Manager.
If above folder is not found. Then,
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
on Jan 18, 2010 | Computers & Internet
I don't see the Acer images in the screen when I change the sound, no escale at green or when I try to play other screen doesn't appears the window option
I don't see the Acer images in the screen when I change the sound, no escale at green or when I try to play other screen doesn't appears the window option? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
1742SEA1P 715G1492 1 ACR Acer ADTV1742SEA1P Power Supply Backlight...
Sep 04, 2011 | Acer Aspire 1640Z Notebook
I am getting a warning about insufficient dik space on my Archos 101 16 GB running on Froyo, but when I go to configuration, it reads 14 gb of free space. Any advice on how to manage and optimize disk...
That system warning relates to available application space. For some reason Archos only devoted ~128 MB for applications, so you can fill that up pretty fast. You'll need to:
uninstall applications (settings, Applications, Manage Applications, then select and uninstall some)
or
move some applications to "internal storage", this transfers some of the space they're taking to the internal storage on your Archos. Again you'll go to Settings, Applications, then Manage Applications. From the list of applications select some of the larger ones and you may see a "move to internal storage" option. Some apps have this, some don't.
Feb 21, 2011 | Archos 101 Internet Tablet Notebook
How to install an application for my blacberry cellphone
If you would liketoinstall application using the application loader tool in the Blackberry Desktop Manager.
You should verify that the application to be installed on the BlackBerry smartphone is saved to the computer before completing the following steps.
If you are using BlackBerry Desktop Manager version 4.5 to 5.0 then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, click Application Loader.
  3. Click Start where it says Add / Remove Applications.
  4. Type your password, if prompted, and click OK.
  5. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
(french)i have bberry curve 8330 and i receive a eror code 205..
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
Jun 09, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
I get this: App error 205 / reset - Hour glass keeps running. I removed the battery several times.
May 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Nokia 6600 Logo
53 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
