Question about Wilton Variable Speed Wheel Grinder, Bench Model Belt, 1HP, 1PH, 115V TEFC Motor with AC Inverter
Have 25 year old Wilton belt grinder. Belts seem to wobble when running then will just not track. Not sure what part needs replacement.
    Brigadier General:
  • 4,088 Answers
The motor and grinder pulleys need to be perfectly parallel or the belt will track to one side or the other. The belt must be uniform with no stretch or wear points which will cause erratic travel. Hope this helps!
Posted on Jan 10, 2011
Where can I get a cookie press? My old one just broke after 25 years of using it.
If you are looking for a very simple cookie press, you could try amazon; http://www.amazon.com/Wilton-Cookie-Pro-Ultra-Press/dp/B000I4OJ1E/ref=pd_sim_k_1
But if you want to replace your broken one with something a bit sturdier, take a look at this link:
http://www.wilton.com/store/site/product.cfm?sku=2104-4018
Feb 28, 2013 | Baking
Whats wrong when my front end has a wobble in a 95 camaro
The first thing I would do is to jack up the car and inspect the lug nuts to make sure they are tight. Then spin the wheels by hand and look to see if the wheel is bent any. If the wheel is bent it will wobble. Next spin it again and make sure the tires don't have any broken belts in them. If you have broken belts it will look like the tire isn't perfectly round, and the tire will wobble while the wheel runs true. On some models that use old style lug nuts they can be installed backwards. If you have what are called acorn lug nuts you can only put them on one way. If you have the old type the angled surface goes in. If these are on backwards the wheel can wobble. If this all checks out you need to look at the steering components, you probably have some worn out parts. For most people the front end inspection should be done professionally. This is because it is beyond the capabilities of most DIY people.
Dec 06, 2010 | 1995 Chevrolet Camaro
17202 8'' bench grinder 3yrs old hasent run 1 hr needs on off switch wilton stated after 6mos of waiting for soposed back order that co that maid these for wilton is out of business they said try lowe;s...
go to your local marina and buy a simple on off switch or take the wires off the switch on your grinder and hook them up to a extension cord and put an inline light switch on the cord.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
I have an Abbott & Ashby 200mm Industrial Bench Grinder - CS-8GCM I need to change the sanding belt and am unsure how to do it, can you help?
Remove/open cover on the right side of belt assembly housing. push downward on tracking knob left side top of unit.Belt is spring tensioned to remove slack.Push down remove old belt,push down again for new belt.With belt running adjust belt track(centering) by turning knob,top of unit,toward or away from you,Arrow on inside of new belt governs direction of rotation of belt.
Jun 09, 2010 | Sander 6" Bench Grinder 2" Belt Combo...
Denon Stereo audio cassette deck DR-M30HX traction prob thin tape
Belts for decks are universal, there are plenty of places on the web selling them. Parts for a Denon from 25 years ago is another matter. However I think you might need only the belts, as the longer tapes speed problems suggest that it's the load that's causing the belts to struggle. All you need to do is measure the diameter of any belts for replacement. HOWEVER before you remove them make a note, or photographer, how and where they fit.
Use Servisiol Video 40 to clean the rollers and head.
Feb 01, 2010 | Audio Players & Recorders
Have a two clear view probably 3 year old belts
sounds like the motor bearings are bad. when those bearings wear out the motor shaft doesnt stay strait and allows the belt to track off.
Jan 16, 2010 | Bissell CleanView 3596 Bagless Upright...
Shredding belts
first make sure the belt is not hitting anything when the blade is engaged (engine off), the if ok remove belt and look in pulley grooves for rocks or chips., then run finger all around groove to make sure there is no catches or spurs. If that is all ok then with belt on and engine idleing as slow as possible and blade engaged look and see if pulley is wobbling, BE CAREFULL !! look at the engine pulley first then with EXTREME CAUTION look under deck from opposte side of chute. ( Check with deck at highest setting)
Jul 24, 2009 | Mtd Garden
Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Jul 23, 2009 | Polaris 380 In Ground Pool Cleaner
Dryer won't start
belts, as in 2?? you do have an old speed queen. did you make sure the blower is able to turn freely?
if so then you most likely have a bad winding in the motor. it is costly to replace and you should go out and get a new dryer. too much money to fix this old unit.
by the way the model number is under the front panel in the center, on a metal plate.
doesnt matter since you know its 25 years old and its time to update.
Jan 22, 2009 | Dryers
Wilton Variable Speed Wheel Grinder, Bench Model Belt, 1HP, 1PH, 115V TEFC Motor with AC Inverter Logo
163 people viewed this question
Top Wilton Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
bob walter
bob walter
Level 1 Expert
Are you a Wilton Grinder Expert? Answer questions, earn points and help others
