Question about Sony KP-53V75 53" Rear Projection Television
Everything in the picture is off. lots of pink and green involved and it droops in the middle at the top so the letters all curve down
    President:
  • 1,082 Answers
This is very common for these types of TVs. Has it recently been moved or bumped? Or possibly exposed to a surge. - READ Warning below.
This is an issue with the color guns being out of alignment. This will require a TV expert to fix. The color guns are controlled by wire field coils wrapped around the CRT or main picture tube. Possibly the glue used to hold them in place may have let go some. I kinda know what to do, and I find it very difficult to do a good job of aligning the guns to produce a clear picture. Take it to a TV repair shop or have them come out to you would be better, because once aligned, it may shift again while being transported home.
WARNING. There are VERY high voltages in back of your set. In the 40 thousand volt range or more. Don't mess with it yourself unless you KNOW what you are doing. Don't guess.
For the money - I'd look at a new flat screen.. !!!!
Posted on Nov 09, 2010
I have a Mitsubishi 55"
This set has a convergence problem. You should only need to replace the IC. Part is STK393-110. It sits on the middle board behind the large heatsink. Use a heat transfer compound to ensure repair lasts. If you have no experience soldering (or unsoldering) please use a professional for the work. The traces are fragile and I have fixed many mistakes local DIYers have committed. Goodluck.
Jan 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Green and red a little blue everything is doubledup lines droop down from the top everything is dropping to the middle
CONVERGENCE PROBLEMS. WILL REQUIRE PARTS REPLACEMENT. POSSIBLE VERTICAL DEFLECTION FAILURE ALSO
Dec 27, 2009 | Zenith R57W46 57" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Picture stretching with Red, Green, and Blue Image Overlays
assuming that you have adjusted the convergence and this had no effect. you might have some blown convergence chips and/or resistors. these make the 3 color line up with each other.. my 55 in phillips did the same thing and the more i used it the worst it got. first it was the blue and the red and finally the green., replaced chips and resistors and the problem went away... good luck.. a lot of soldering involved. but the chips are only like 11.00 each and the resistors are like ten for all three.
May 30, 2009 | Sony KP-43HT20 43" Rear Projection...
Everything works but looks animated with green and red
Sounds like a classic case of a convergence problem. If you give me a model number and a manufacture i can help your further.
Thanks
Tim Nolan
Sep 24, 2008 | Televison & Video
Line at top of screen
There are problems in the vertical blanking or scanning circuits. This is not something you can fix yourself at home. It involves troubleshooting the deflection amplifiers and scan generator areas to locate the defective components.
You will have to give the set out for service. I would suggest to get an estimate before proceeding. This type of repair can be costly for the labor to find the fault. If it is only generic type parts involved, the parts themselves will not be too expensive.
Jerry G .
Jul 09, 2008 | Samsung HC-P4752W 47" Rear Projection...
Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Dec 31, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Curved picture
ur problems is on the pincushion check for a capacitor that its bad on the pincusion section  good luck.
Nov 01, 2007 | Televison & Video
Sony KP-53V75 53" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
