Question about Mitsubishi WS-65909 65" Rear Projection Television
Tv always turn off
My mitsubishi tv ws 65909 always turn off, when i try to turn it on.
I tried the menu + select device button, it gave me error code 23 " blink-blink"... "blink-blink-blink", then it repeated about 5 times.
what wrong with it ? what should I do with it?
Thank you very much in advance!
  • 2 more comments
  • wqneu Jun 16, 2008
    what should I do next step?
    is it easy to replace the parts by myself?
    If it need, walk-in service, how much it would cost in general?
  • wqneu Jun 17, 2008
    I pulled out the power cable. after 30 minutes, I put the power cable back, then I tried to turn on the TV, the picture just flashed, then the TV is turned off again.
    Thanks for the detail information!
    President:
  • 2,712 Answers
You have a problem with the power/main board and a couple parts need replacing.
I have a site here that will give you the service manual (If you wish to try a DIY, as well as online support if you buy the manual from them; although I dont recommend it if you have no experience, as there are voltages that can KILL, even with the set unplugged).
http://servicemanuals.vstore.ca/
they will even assist you in finding replacement parts for your board. That would be you best option.
It may cost you a bit more for repairs, but will serve you well in the long run..Hope that helps!!
If you found my advice helpful in any way. kindly take a moment to "ACCEPT" this solution.
Thanking you,
IrishDruid
Posted on Jun 17, 2008
  • 1 more comment
  • Swilin Sampson
    Swilin Sampson Jun 17, 2008
    Sorry..with due respect to Midwest-tech and leethedeuce...
  • Swilin Sampson
    Best advice, and my most honest opinion would be to look for a new set, as although this can be fixed (costing you nearly half of what you paid in the first place).
    A newer model model would be worth investing in , considering the issue at hand. I am not saying that you cannot attempt a DIY.try it by all means if you can, but if you have no prior experience, best leave it to the Experts..
    Wish you all the best, I
    rishDruid
  • Swilin Sampson
    BTW, if you found my solution helpful in any way or led you to a fix, kindly take a moment to "Accept" my solution, thanks..
  • 6,487 Answers
Base from your problem descriptions this one should be handle by a professional electrician for your safety also, if your unit is still under manufacturer's warranty better bring it back to them and have it repair, but if its not under warranty bring it to the repair center near you and probably you need to spend around 300 to 500 bucks.
Good luck and hope that help...
    Sergeant:
  • 243 Answers
It looks like that board runs about $223 if thats correct and it would be about 150 in service fees to my best guestimate. Give me a moment to look up the error codes.
hope this helps thanks,
Nate
Posted on Jun 16, 2008
  • 4 more comments
  • Nathan Ayers
    Nathan Ayers Jun 16, 2008
    leethedeuce has the correct code. That board costs about 223$ to purchase online. so i would say your looking about $300-500.
  • Nathan Ayers
    you could do it yourself
    heres the ic information to do it yourself on the cheap. but you need to resolder an ic to the D-board
    CHASSIS: V19
    MODELS: WS–55859 / WS–55909 / WS–65869 / WS-65909 / WS-73909
    this is the IC IC8C01
    part number
    267P155010
    HIC - STK393-110
    hope this helps
  • Nathan Ayers
    id say its only easy to do an IC if you have experience in soldering capacitors to a board. For replacement of the D-board itself, is generally pretty easy.... it vary from tv to tv.
  • Nathan Ayers
    Nathan Ayers Jun 17, 2008
    you have a failed IC on the D-board as i listed before You can attempt to replace it yourself. Or take it to a tv center and have them order the IC's and replace them.
  • Nathan Ayers
    this is what is indicated by the error code 23.
    Let me know if you have any other questions about replacing the D-board or The IC's as i listed on a previous comment. As i will be glad to help you understand or figure out anything you need.
    hope this helps you and if so please rate accordingly.
    Thank You,
    Nathan
  • Nathan Ayers
    marked why would you copy my exact solution.
    i feel myself and leethedeuce provided more then accurate description
    to we problem. I believe we saved you a service technician and gave
    you the proper diagnosis.
  • 4,472 Answers
Here this coveres all the error codes.
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
1â• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
2â• The flashing then pauses for approximately 1/2 second.
3â• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
4â• The Error Code is repeated a total of 5 times.
Example: For Error Code is "24", the LED will flash 2 times, pause, and then flash 4 times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
"12" ... indicates no error has occured.
"21" ... X-Ray Protect circuit.
"22" ... Short Protect circuit.
"23" ... Horizontal Deflection failure.
"24" ... Vertical Deflection failure.
If you find this helpful please accept this solution and let me know if you need any further assistance.
Thanks,
Lee
  • 9 more comments
  • Lee A.
    Lee A. Jun 16, 2008
    Is the unit still under warranty?
  • Lee A.
    Lee A. Jun 16, 2008
    If you are handy, and can solder, you may be able to save about 700
    bucks if not more. There is a very common problem with these Mitsubishi
    TV sets. There is a digital board inside these puppies called the DM
    board. A lot of times there are four capacitors that go bad inside of
    these TV sets. Sometimes, depending on how bad the capacitors are, and
    if the capacitors did not blow out anything else on the Dm board, you
    can simply replace these four capacitors and this will fix your TV set.
    The average that this works on is about 65 to 70 % of the sets can be
    repaired with this fix. The others are power supply issues or the DM
    board has other issues.
    I would advice having it done though as if you are not 100 percent sure you should not attempt.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Yes that will happen when these parts are bad.
    My proposed solution should be more then acceptable. If you could please give me a positive rating it would be greatly appreciated as I strive to provide you quality service.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    If you need any further assistance I will be more then happy.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Was there something I could further assist you with?
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    This is the solution to your problem? Is there a reason why you did not accept it?
    I wait for your reply,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    You will not get any more answers then the ones you have gotten. Unfortunately in this business you will not always like the answers but that doesn't mean it is not the best option for you.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    The next step is to have it serviced.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Thanks marked for giving the same answers again.
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Which only proves further that all the solutions you could possibly be given have been presented. I hope you accept my solution.
    Thanks,
    Lee
  • Lee A.
    Lee A. Jun 18, 2008
    Anytime you need me don't hesitate just use the Ask me feature.
    Thank you very much and you are very welcome.
    Lee
  • 197 Answers
Turn it off for 20 minutes to discharge completely..then see if it's the same thing again
  • P.Michael D'Acre
    P.Michael D'Acre Jun 16, 2008
    did you turn it back on?
    Master:
  • 555 Answers
It looks like you have a faulty power module.
  • Matt Jurach
    Matt Jurach Jun 16, 2008
    2-3 blinks = Deflection protection shutdown (this could be loss of vertical or horizontal deflection)
Ws-65909 power light goes out after 3 seconds no sound or picture
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Oct 26, 2012 | Mitsubishi WS-65909 65" Rear Projection...
I try to switch the TV on (either using Power button on the remote control unit on TV itself), but the TV switches itself off immediately. I tried it many times, quickly in succession, as well as after...
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
MAKE A COMMENT HERE and I will help.
SD TECH
Sep 18, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I have a Mitsubishi 65" Big Screen TV (WS-65909). I cannot turn it on. When I press the power button, the "Timer" light stays on for about 3 seconds and then turns off and nothing happens. TV does not...
tO KNOW WHAT THE PROBLEM IS YOU HAVE TO DO THE SELF-CHECK that this model has.
After you turn it on and the power light goes off:
On the front of the TV press and hold both Menu and Input (or device) TOGETHER FOR AT LEAST 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light will blink an error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means. 2,2 is most common and the least expensive to fix.
If this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
sd tech
Nov 09, 2009 | Televison & Video
My 65 inch projection TV turns off within a few seconds when I turn it on. Why? No pictures or sound.
If power light does come on and a few seconds later it goes off---do the self check that the WS65909 MITSUBISHI should have:
On the front of the set press and hold both the MENU and INPUT(OR DEVICE) BOTH FOR 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light should blink a two digit code--error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what code you get----it will repeat it several times---and I will tell you what it means.
SD TECH
Nov 03, 2009 | Mitsubishi WS-65909 65" Rear Projection...
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Will not stay on., Automatically turns off.
Try pressing in both the menu and device/input buttons in together on the front of the set and hold for 5 seconds to see if the led will blink a two digit error code such as 2 blinks then a pause then two more blinks followed by a pause which would indicate a 22 error. Then let me know what the blink code was if any.
May 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55908 Rear Projection. Doesen't Stay on.
have you tried to access the self diagnosis feature by holding the menu and device/input buttons on the set both in together for five seconds to see if the led will blink a two digit code such as two blinks pause two blinks for a 22 error? Try that and let me know the blink code and i can assist you.
May 21, 2009 | Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
WS-55511
Press in together the menu button and the Device/input button on the set and hold them both in together for 5 seconds and see if the led will blink a two digit error code, then respond to this same post and let me know if it gave a error code and what the two digits were.
Aug 02, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
217 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
