Question about Maytag Refrigerators
What temperature should my maytag side by side freezer be set to it has an ice maker and water dispenser thanks
  • 316 Answers
Your refrigerator temperature should be between 35-40 degrees F, the freezer should be 0-8 degrees F. Both of the control settings should be in the middle, so if its on a scale of 1-9, 5 is middle, if its on a scale of A-J, E or F would be the middle, if its a temperature setting, 37 and 0 is normal setting.
Posted on Nov 09, 2010
We changed the filter for the water, now it will not dispense water, but the ice maker still works.
Hello nott225 - The issue sounds like it might be related to the temperature in the freezer. What is it set to? Make sure that the temperature is approximately around 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. If it is properly set, then consult a professional to accurately pinpoint any potentially more serious issues like a faulty ice maker valve or even the ice maker itself.
Feb 03, 2013 | Frigidaire FRS23H7CS Side by Side...
My maytag msd2657heb i could hear it running but the fridge and freezer not cold at all
It can be faulty compressor or issue with defrost.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice maker not making ice
check the water solenoid for the ice maker on the back
Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
No water from water dispenser in Whirlpool et1fhtxmq03 refrig.
Most likely the water control valve on the back of the refrigerator. One side controls the water to ice maker and the other side sends water to the water dispenser. This is providing the water didn't freeze during the very low temperature setting set before you turned it back dow. If you can locate the model number I will be able to get the part number for the water control valve. There is a way to test it with an OHM meter, just let me know, Thanks, Sea Breeze
Jul 26, 2009 | Refrigerators
Ice maker sprays water...
sounds like the inlet part on the ice maker is froze over or not lined up in the opening of it right or a possibilty that the ice maker is leaking out the water if that is the case the ice maker needs replaced
Jun 07, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Water to ice maker isn't filling tray.
what is the inside temperature in the freezer? it has to be below 17 degrees before the ice maker even try's to work
Dec 11, 2008 | Frigidaire FRS26R4A Side by Side...
Icemaker won't dispense whole cubes, only chopped ice
Hello chitwnchk1
Welcome to Fixya,
You said,It chops ice when dispensing but won't just dispense whole cubes.
Any suggestions on how to fix it?
1. If the cubes dispense, but not whole cubes, there is not a enough water pressure.
2. r there is a restriction in the water line to the ice maker.
3. OR the fridge may not be level.
4. Is there a water filter and has it been Changed in the past 6 months?
Here are 4 reasons mentioned in the repair manual.
Shutoff arm in the off position
Ensure the shutoff arm is down and not in the raised position. If in the raised the position, the ice maker is in the off position and will not cycle.
Faulty Harvest Thermostat
There is a thermostat inside the ice maker that will close when the ice maker mold reaches the proper temperature. If the thermostat is not closing, the ice maker will not cycle.
Freezer To Warm
The ice maker will not cycle if the temperature in the freezer in not below 12 degrees. Ensure proper temperature in freezer.
No water getting to ice maker
The water inlet valve is the control device that allows water to enter the ice maker. It is energized during the last 5-8 seconds of the harvest cycle. During this 5 to 8 second period, there should be 110v across the two wires connected to the valve . If there is power supplied to the valve and the valve does not open to allow water to flow, the valve is defective.
However, if power is being supplied to the valve and water is flowing through it freely, it could be that you water supply line or inlet tube have frozen solid. These can be thawed with warm water or a hair dryer.
Let me know how it goes and what you found!
Thank You , Huuuum
Please remember to leave a rating!
Oct 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag side by side multi problems
1. Ice maker is not cold enough to start the ice making process.
3. having to take off the back panel is an indication of a problem in the defrost system. Call to have a service tech check this out.
May 15, 2008 | Maytag MSD2756GES Side by Side...
Refrigerators Logo
839 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
