Question about Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to reset channels on sharp model lc-46d43u as when we got tv technican set all channel and password and we do not have password to go in setup so cannot change now as for digital half channel are not rorking as they are on analog as for channel services i have to scan all channels in digital mode now
doctox
  • 51 Answers
SOURCE: Satellite feed is analog instead of digital
change your connector
Posted on Jan 16, 2008
micromaster
  • 3614 Answers
SOURCE: DCR SET NOT RECEIVING ALL DIGITAL CHANNELS
it has to be re-program your tv set. maybe you can call your cable provider for assistance to program your channel.
Posted on Feb 14, 2008
SOURCE: TV No Picture
My 32D40U would turn on for 5-10 seconds (Please Wait would appear) and the screen would go black. Sound Normal. It would also sometimes do this after running 5-10 minutes. I read somewhere that the inverter board would come loose and lose proper ground. I took the set apart, removed the board, and cleaned up the grounding points. I reassembled using some copper paste on the ground points and LockTite on the screws. I used some contact cleaner on all the connectors going to the board. I noticed two cables that are covered with copper shield tape where too tight at their connectors and repositioned the tape to give them some slack. The problem hasn't occurred since the fix.
Posted on Mar 22, 2008
jerryg50
  • 1667 Answers
SOURCE: Sharp 20" LC-20B4U-SM
I cannot say pariculary for this model, but on some models of TV sets, if the channels are not programed as part of the channel list, they are muted.
Turn on the TV, and perform the channel auto setup.
Jerry G.
Posted on Apr 12, 2008
rapanSF
  • 150 Answers
SOURCE: Sharp Aquos LC-52D64U LCD-52 wdscrn tht won't scan in digital...
Seeing that you have a superior brand and not getting channels is a bummer. It may have to do with the setting, make sure you're set to cable rather antenna and then do a rescan. Btw, often times channels from an over the antenna is much clearer than from cable because cable tv has to compress the signal. If you're high in the air like the top floor of a building a cheap $10 will pull in great free digital channels. It helps to experiment and read the troubleshooting guide in your manual.
Posted on Dec 03, 2008
How do I get the tv to scan for channels
For the LC-xxLE Aquos models the channels can be setup using the Menu button and going to the Initial Setup -> EZ Setup screen. Choose the home and air/cable options and start the channel search. If you have a working antenna or cable input, the TV will discover all the working channels.
Feb 01, 2016 | Sharp Aquos Televison & Video
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
I need to do a channel scan on my tv to get the service working but i cannot find channel scan options on the menu. Where is the channel scan option on the sharp LC-32SB24?
During power up and first time use, there should have been an option for channel scanning as the initial setup wizard began.
Alternatively, there should be a way to navigate to the channel scanning menu by selecting, Menu>TV>Auto Channel Search. I couldn't get the exact info from the model you listed, but I gathered this info from a similar owner's manual (lc-32sb28ut) from the Sharp webpage: http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
Hope this helps.
Oct 17, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Varous tv channels do not have sound. It is NOT a
TO: rdh041: I don't have the solution to you problem, but we have the exact same problem with our Sharp AQUOS 20" LC tv. Different model than yours, but same age and same perplexing issue. Several channels suddenly have no sound. If you've found a solution, would you please post it? I'll do the same. Thanks.
Jul 15, 2010 | Sharp Aquos LC-20B6U/LC-20B6E 20 in....
I purchased a lc-19sb25u sharp and ive got SOME of the channels they just don't have the right channel number as the rest of my TV's???
Did you go to Menu - Setup - EZ Setup - then perform the Channel Search? It programs the channels that way.
Jun 28, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
I ACCIDENTLY SEEMED TO ENTER A CODE TO BLOCK CHANNELS IN MY TV SET AND NOW DO NOT REMEMBER WHAT THE CODE IS? IS THERE ANYWAY I CAN RESET?
To reset/clear the password for the LC-32SH12U TV, PRESS and hold both VOL-- on the TV and press 0 on the remote control simultaneously for a few seconds until (LOCKS) menu appears on the screen.
Now the old password was cleared. You can set the new password.
May 28, 2009 | Sharp LC-32SH12U TV
Can't get all my cable channels
what cable company do you have because you should have a cable box because only a cable box can scramble the frequency so you can get the channel you subscribe for
Dec 17, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Jerry G.
Nov 20, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp Aquos LC-46D62U 46 in. LCD HDTV Logo
124 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
