Question about Dishwashers
The bottom rack cleans fine, but the top rack is not getting cleaned at all. I know there must be some kind of blockage but do not know where.
  • Dishwashers Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Nov 09, 2010
Why doesn't the top rack of my dishwasher clean dishes?
the water tube may be clogged at the sprayer on the top of the basin. probably have to disassemble and clean
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Apr 14, 2016 | GE Dishwashers
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes will not come clean in top rack. Checked all areas for blockage, found none.
make sure that the rotator sprayer for top rack is not jammed or blocked, remove it and check.
ensure that your machine is not set to 1/2 load if in this setting the machine only washes bottom rack you need to have set for full load to wash both racks.
I hope this was helpful.
Jan 24, 2011 | Dishwashers
Dishes in the top rack not getting clean. Bottom rack is fine.
Your filter/chopper is clogged. You have to clean it out and that will restore water pressure to the top rack.
  1. Remove the bottom rack.
  2. Remove the top rack
  3. Remove bottom Spray arm (turn top nut clock wise)
  4. Take off the delivery tube by turning it clock wise over the heating element ( undo the two clips one at the back and one on top)
  5. Take out the screw for the top screen and remove top
  6. Take one screw out for chopper housing and remove
  7. Remove chopper and clean or replace chopper if broken
Reinstall all parts and test.
That should help please rate your experience. Thanks
Dec 11, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Dishes, glasses on the top rack dont get cleaned. The bottom rack is fine. What may be the problem?
Probably a blocked spray arm. Remove the top spray arm and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Jan 25, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Dishes on top rack do not come out clean. Bottom rack O.K.
Have you tried cleaning the filter? We had a similar problem. The repair man came and removed all the spinners and the other stuff at the bottom above the motor to get to the filter. It was blocked with all kinds of old food bits and pieces, the odd bit of plastic film etc. He cleaned it, replaced it and we havn't had a problem since but he said it needs to be done about every two years. It can be done by someone who has reasonable DYI skills.
Jan 04, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
