Question about Hoover H160E Front Load Washer
Super wash and start light flashing
When draining or spinning the super wash and start light flash and no spinning or draining take place
  • 1 more comment
  • mcqubri Jun 24, 2008
    fixed by reconnecting temp sensor at rear of drum with loose connection
  • steve boust Jul 19, 2008
    There is no spin action and the 'super wash' LED flashes 3 times then a long pause then 3 times again & so on.
  • tictok_uk Oct 28, 2008
    On certain programs (those that require fabric conditioner) the cycle doesn't finish. After the main wash is completed, the machine stops and the super wash and start light flashing.
    The fabric conditioner part of the cycle doesn't start and neither does the final spin.
    However if I choose a program such as the 'everday 40º wash', the program completes successfully.
    I've checked filters and drainage. All appear to be okay.
    What does the feeder tube do? Could it be related to that??
    Thanks
SOURCE: Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Posted on Mar 16, 2007
geemarie
  • 876 Answers
SOURCE: Nextra AA1200
You may have a plugged drain hose. Or possibly your household drains are running slowly. To check the hose, pull the washer out. Turn it off and unplug it. Disconnect the drain hose (the 2" black hose) and see if you can clear it of any clogs. You will need some towels and a container for catching any water.
Leave the washer unplugged for a time (don't get the plug wet) while you check other drains in the house, especially the garbage disposal and toilets.
Plug the washer back in and turn it on and try a cycle.
This is the most common problem for what is happening with your washer. If this does not fix your problem, you may need to call a serviceman, or if you do have slow drains elsewhere, a plumber.
Thank you for uisng fix ya! I would appreciate a rating on this solution.
Posted on Aug 22, 2008
  • 99 Answers
SOURCE: Hoover VisionHD won't drain
This is joyce
I think you better check to see first of all if it is your pump,, that is the first thing to go.
thanks
joyce
Posted on Feb 07, 2009
  • 13 Answers
SOURCE: Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Posted on Apr 13, 2009
localwonder
  • 6784 Answers
SOURCE: wont drain and start light and pre wash light
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Posted on Jul 08, 2009
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
Flashing and beeping red spin light. won't spin
Have you emptied the filter recently. If it's clogged, the machine can't drain or spin.
Nov 15, 2013 | Washing Machines
Kenmore super capacity washer3.5 not working lights flashes and stops
This is usually a sign that the drain pump filter needs to be dumped or an object has jambed the pump mechanism.
Jan 30, 2013 | Kenmore 3.5 cu. ft. Front Load Electric...
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
My dryer starts up for less than a minute and than starts beeping and all lights start flashing. For a while i was able to change settings from 60 mns to towels and it would work. Now it starts for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2010 | Dryers
I have the hotpoint BWM129 super silent 1200 spin, recently the machine has stopped draining water even after spin cycle has finished , I also have constantly flashing lights which are super wash and delay...
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Feb 18, 2009 | Hotpoint BWM12 Front Load Washer
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hoover H160E Front Load Washer Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
