Question about Panasonic NE-1064 Stainless Steel 1000 Watts Microwave Oven
After repeated use it runs but stops heating - Panasonic NE-1064 Stainless Steel 1000 Watts Microwave Oven
  • 17,970 Answers
This is a problem with the inverter or a bad magnetron. Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
Make sure it has a good airflow around it, check the vents to see they are not blocked off by some object or dust. I suspect the safety sendor is turning the unit off to prevent overheating.
Also inside your microwave is a big capasitor it holds 000,and 000s of volts if you do go inside it and tuch this cap, it could or would most likley kill you. Is it worth being killed for a fuse thats not blowen? I would recommend that you contact your nearest Panasonic-authorized servicer.
Keep us updated.
Posted on Nov 09, 2010
Microwave runs good for short heatups. But long or repeated heatups the microwave gets warm and shuts down. Will restart after cool off.
Magnetron thermostat is sensing over heat condition, it the fan running to cool it while running
Nov 21, 2015 | In Microwave Ovens
How do I fix my microwave oven?
Is it a rust on the connection part of the electric? I know many people rely on it when comes to cooking and heating up leftovers. Also for heat therapy. Best Neck Pillow and heating pad.
Sep 11, 2015 | Whirlpool Microwave Ovens
Ge adora over the range microwave, runs but does not heat
Microwaves contain high-voltage parts that can be deadly, even when unplugged, unless handled correctly. Unless you are a qualified expert, don't attempt to get into its inner workings.
First, use this water method to double-check if there is actually an issue with your microwave not heating:
1. Fill a glass measuring cup with water to the 1-cup mark.
2. Set the microwave to heat on full power for 1 minute.
3. Repeat the process with fresh water a handful of times.
4. If the water is not consistently warm, your problem is confirmed.
If your microwave is failing to heat correctly, you may be on a previously programmed setting. Press the STOP/CANCEL button and start the heating process again, but use a higher power setting. This may correct the problem.
If the microwave senses an open door, it will not run. Check to see if a defective or loose door-safety interlock switch is to blame. If tightening it doesn't work, a replacement may be necessary.
Did you know? Neglecting to hit the STOP/CANCEL button on the microwave before you open the door to remove your food damages the safety switch over time.
Microwaves installed above the range may be affected by steam from cooking. Condensation collecting on the circuitry can interrupt heating. Allow the circuitry to dry out by avoiding stovetop cooking for a few days. If you're still having the same problem, it could be a loose connection in the circuitry or a faulty door safety switch.
There may be an issue with the circuit board and its connections, and that work is best left to a qualified professional.
A buzzing or humming microwave that emits a faint burning smell could signal a damaged magnetron, high-voltage capacitor or diode. Replacement magnetrons are expensive, so if a service professional determines that's the problem, you may be better off buying a new microwave. Capacitor and diode parts cost much less, but remember, you'll be paying for the expertise to have them installed correctly and safely. It may still make more sense to buy a new microwave, especially if it's a simple countertop model.
For more troubleshooting steps and simple solutions, read Microwave not heating. I hope this helps!
Sep 28, 2012 | Microwave Ovens
Runs but doesn't heat replaced two fuses and magnetron still doesn't heat
Here is your free answer in under 10 minutes ...
You have a faulty door safety interlock switch. I wish you would have searched your problem here before you spent all that money on the magnetron. I have answered this question dozens of times here at this site.
When the oven runs but doesn't heat, more often than not it is nothing more than a faulty micro switch in the door latch system. When the switch doesn't work properly, the oven doesn't know the door is closed. If the door isn't closed, the oven will not energize the magnetron. Capacitors and magnetrons are **** and expensive answers but these items are extremely tough. It is the tiny contacts in the micro switch that can not stand the repeated abuse given them when we (read me in that number too) open the oven while it is energized causing a repeated flash across the contacts.
Thanks for your question @ FixYa.com
Aug 06, 2011 | Microwave Ovens
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Microwaze suddenly stopped heating food, runs well but just does
take outer cover off look inline with the black wire
Aug 31, 2009 | Microwave Ovens
Wont heat
If the diode is good (not shorted) then I would suspect the magnetron.
Here are some tests that might help:
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | Amana ACO1860 Microwave Oven
Kbms1454r
Your magnetron is leaking and needs to be replaced.
Oct 29, 2007 | KitchenAid KBMS1454R Microwave Oven
Self start when door closes
if electronic control, one of two things come to mind. 1)your toutch pad is defective.replace it. 2)you electronic board has a leaky component.not very likly though. believe it or not, ive seen it start before by itself then i noticed a large quantity of bugs inside the glass which i realised triggered the microwave 0ff.
Jul 23, 2007 | GE JVM1460SA Microwave Oven
Panasonic NE-1064 Stainless Steel 1000 Watts Microwave Oven Logo
27 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
