Question about Kenmore 74602 Gas Dryer
My dryer runs but doesnt heat up, and makes a sound every so often
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Nov 09, 2010
My dryer does not heat up but the drum is turning
Just because the drum turns doesnt mean its drying. The dryer has heating elements, sounds like they need to be checked or replaced. Check lint trap, and make sure no dust in the tube in back of dryer are clear. If they are it may be the heating elements.
Sep 13, 2016 | Dryers
Kenmore dryer dont heat
In most cases it's not a bad heating element there are a few checks you need to make before buying a new heating element, you can follow this guide to make the repairs:
Electric Dryer Runs But Dont Heat
Feb 11, 2014 | Kenmore 63942 Dryer
Not heating
sounds like a heat sensor to me. Sorry but you will have to get it tested or buy both sensors on your heat element. look in the dryer as its running... Does the heat coil turn orange in the dark???? If it doesnt you will have to replace the heating element.. (should be about 75 bucks)
Nov 02, 2009 | Whirlpool Dryers
My Fisher Paykel dryer runs as normal just doesnt put out any heat.
Usually when an electric dryer runs but stops heating, the heating element has failed and needs replacing. I don't know if you are a do-it-yourself type, but you can get the model/make/serial information and obtain the correct element at your appliance parts store.
I hope this helps... Good luck.
Oct 23, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer runs but doesnt heat. Used to just unplug and replug cord and would work but now even that won't work
Sounds like you have to replace your thermostats in the back of the dryer. Also check to make sure your heating element is good
Sep 24, 2009 | Bosch Nexxt WTMC 6300 Electric Dryer
Dryer model LER6620PQ0 dryer runs, but will not heat
If drier runs and doesnt heat, it can be one of two things. 1)The over temp. th/stat has activated. Possibly it can be reset. or 2)the actual element is faulty, which would need replacement.
Sep 21, 2009 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
My dryer seams to work fine but when i turn it off the heating unit doesnt go off
Hi, Sounds to me like the heating element has shorted out against the cabinet. What make/model# is this dryer?
Vic
Jun 27, 2009 | Dryers
Buzzing sound
This could be caused by vibration of the element coil supports (ceramic pieces that hold the element) as the machine is running. It could be intermittent due to the expansion and contraction of the coils when heating up and cooling down. See if moving the dryer while it's "buzzing" makes any difference in the sound.
If this is the case, you can replace the heating element or try re-leveling the machine. As a quick fix, tweaking the coil or supports is also possible but I wouldn't recommend this unless you feel comfortable doing so or you have experience.
Feb 15, 2009 | Kenmore 84052 Dryer
Kenmore 74602 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
