Question about Panasonic Audio Players & Recorders
My receiver SA- TX50 will com on ,work some time and shuts off. Comes on again and shuts off.What to do?
3 Suggested Answers
  • 899 Answers
SOURCE: I am trying to set
1. cable box video out to video 1 in on the lcd , audio out to reciever input 1 ( tv, vcr , or what you want it on )
2. dvd s-video output to lcd video 2 s-video input , dvd audio out to reciever dvd/cd audio input , and add the optical or coax cable digital audio for dolby digital surround sound
electech
Posted on Nov 26, 2008
  • 47 Answers
SOURCE: my Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Posted on Oct 11, 2009
Overload display
Follow the course of the capacitor using the printed circuit board track. It should leave to an semiconductor (IC or Transistor). Replace that. As that will be causing the cap to blow.
Apr 26, 2014 | Technics SA-TX50 Receiver
NO SOUND COMING OF THE SPEAKER
I have the same issue. The power comes on but no sound goes to the AU meters or Output. I have fixed dozens of cold solder joints on the circuit board but it did not fix it. I now am removing the RB1716AB board from the transformer and noticed the black retaining clips are broken. Intermittent connections? Maybe trying to get the clips now.
Jan 17, 2014 | Technics SA-TX50 Receiver
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
Unit comes on ,work and shuts off. Comes on again ,work for a while and shuts off.
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Nov 09, 2010 | Technics SA-TX50 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Oct 11, 2009 | Technics SA-DA10 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
I am trying to set up a SA-TX50 A/V receiver, SH-300 processor, DVD player to my Philips LCD. I also have a digital cable box, seeking assistance. Mike
electech
Nov 26, 2008 | Technics SA-TX50 Receiver
SA TX50
steve4trace on jul 8,2008
UNPLUG the receiver from the outlet. Take cover off. See the circuit board to the right of the dial (front facing U) behind the glass window. The bottom of those circuits are connected by pins that fit the other circuit board. Press them together or tie that corner safely to the back end using non-electrical wire (use poly-twine). When you do this you will not be able to put the cover back on. You will have to leave it exposed. If you like your receiver that much like I do - this is the solution I found. Put the receiver back where it is protected (from kids, juices, water, etc.) and enjoy your surroundsound again. You might have to do that to the other side. It worked for me. Use common sense when looking. Good luck.
Jul 08, 2008 | Technics SA-TX50 Receiver
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
