Question about HP Pavilion Replacement 200w Micro ATX PS3 Power Supply with Video Connector (PSHPPAVILIONVIDEO) Power Supply
At start up, no signal on monitor, computer shuts down.
    Novelist:
  • 206 Answers
Most computer testing facilities will test your current power supply for free. A replacement is very inexpensive to replace. Bestbuy, MicroCenter, small computer shops and buy replacement from Amazon.com, newegg.com.. Just make sure you have the correct information for your replacement. The model number on the power supply would be your best bet in most cases. Good luck and have a great day. I buy power supplies as low as $15 dollars Generic
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Posted on May 13, 2014
Monitor shuts itself down, "no signal" message.
nope. the resolution has bumped up for some reason out of range for the monitor. Does it only happen in the game? that might be a clue.
Feb 17, 2014 | Envision 19" Lcd Monitor H1981
Computer monitor when powered on screen says"saving power" and shuts down?
Try to connect the monitor on other source for signal -laptop or other known working computer.if it posible.
Try with other rgb cable.Moust of monitor go tu stand by or power saving mode when is not presence of signal from computer(h-sync )
If monitor works ok on other source,than problem is in your computer(vga card probably)
Feb 08, 2014 | Computers & Internet
Everytime i start up computer a sigal appears saying "no video input"
I'm assuming after a few minutes, it does get a signal from your computer and all works? It does take about 30s +/- 90s for a computer to generate an output video signal so if your monitor comes on first, before the computer can send a video signal, then you'll see that message. You should see the same message if you shut down your PC and leave the monitor on.
Aug 15, 2011 | Philips 170C4FS 17" LCD Monitor
It shows "check signal cable",
Hi, Hopefully you are seeing this error on the screen of your monitor. If that is the case,
do the following steps.
1 Shut down the computer. To do this, without looking at the monitor, hold the on/off button to your computer in for about 5 seconds. The computer should then shut down.
2 Shut off the monitor.
3 Unplug the video signal cable, the thick one that goes between between the computer and the monitor and then re-insert it observing not to bend any pins. There are two end screws that you will have to be loosened, although they may have not been tightened in the first place. When you reinsert the cable, hand tighten those screws.
4 If there is a similar connector on the back of the monitor, repeat step # 3.
5 Make sure that the signal cable is firmly attached to both the computer and the monitor. 5 Turn on the computer and see if it has solved the problem.
If it does not, examine the cable for signs of damage along it's length.
If it is damaged, replace it. you should be able to get a cable for stores like Best Buy, or possible from a friends old stack of cables.
Hope this helps,
Mark
Jan 04, 2011 | Samsung SyncMaster 2253LW Monitor
I start my computer and the monitor says no signal and even after i shut down the computer the screen stays blue and says no signal. any solutions?
Can you try this monitor with another PC or this PC with another monitor? We need to find where you lose your signal at first before going further.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 30, 2010 | Hyundai ImageQuest L70N 17" LCD Monitor
Check signal cable
There is no problem. The monitor is telling you that it's not receiving a signal. The reason there is no signal is because your computer is turned off, so it's telling the truth. :D
The monitor should go into idle mode on its own, so you won't see that message for very long. It's annoying, but doesn't cause any real problems. You can save even more energy by shutting off your monitor entirely after you shut down your computer. This will make the message go away and also save money on your electricity bill!
Apr 23, 2010 | Samsung SyncMaster 913N 19" LCD Monitor
No video signal, says my HannsG HW191D LCD monitor
This message occurs when the signal from the computer is absent, as in the computer is shut down or the cable is unplugged etc.
Apr 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Just bought a new viewsonic vga1703wb monitor. Plugged it in and turned computer on. Microsoft display comes up and then screen goes black and says 'no signal'. Can you help?
shut down the computer start it again press F8 immediatly and keep pressing untill menu appears highlight on "enable VGA mode" and press enter, your problem will be solved
Apr 11, 2010 | ViewSonic VA1703wb Monitor
Shuts down after a few seconds
hi there, check your power supply on cpu if theres a tripping off , so if theres then replace power supply. then switch it on again. then let me know what happen nexr..
reagards rated me... thanks
Mar 31, 2009 | Acer AL1715 17" LCD Monitor
No signal
This sounds like your Video card might not be compatible with the game you are playing. You might need a better video card. Before you do anthing else, check to see if your computer is fast enough to play it.
Big games can crash slow computers, also it could just be a bad monitor.
Try checking the cord between the monitor and the computer.
Feb 23, 2008 | Acer AL1714 17" LCD Monitor
HP Pavilion Replacement 200w Micro ATX PS3 Power Supply with Video Connector (PSHPPAVILIONVIDEO) Power Supply Logo
61 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
