Question about KitchenAid Cooktops
Kitchenaid range/oven: KDRP467KSSO\r\nDigital time/temp display fades out, replaced the display module, still have problem.
Maytag gas range oven wont cycle
it could be the thermocouple . or thermostat .
Feb 09, 2016 | Maytag 30" Free Standing Gas Range -...
Oven temp fluctuates
It is normal for the thermal device to turn on and off. Obtaining a steady temp is not always possible. When setting a temperature on some ovens, they have what is called a tolerance point. That means a set temperature has a range of a few degrees up or down. At the Down point, the oven is triggered to energize the coils and bring the interior of the oven back to the settings desired. The other factor is opening the oven and allowing cool air to enter, or in some cases a leaking door seal allows air to enter and heat to escape.
Feb 26, 2014 | Kenmore 30" Slide-In Electric Range...
Main oven does not heat at all
Sounds like the heating/starter element went out. This item is very delicate and will break if touched. They are used on almost all newer gas appliances. It takes about 3 minutes to check. Turn the oven on and look down near the burners with all of the lights in the room out. You should see a glow for a while, then it will click off for a while and then come back on. If not, then turn off the oven and get a flashlight and look for the starter element to see if it is broken. It is about one inch wide, two inches long, and 1/4 inch thick. If you do get a glow then this is good news, the element is not broken. However, the element operates a thermostatic switch which operates the gas valve. This switch may be broken. The switch and the starter element usually come out together when removed.
Jan 13, 2014 | Thermador PRL486EDPG 48in Pro-Grand LP...
Kgst307gbs glass control panel replacement
KitchenAid is the most likely source of a replacement
Mar 23, 2013 | KitchenAid KGSS907SSS - Slide-In Gas Range...
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
Kitchenaid KGRT507FWHO gas range not firing or not getting hot
your ignitor is either cracked or bad
gotto sears type in your modle numbber and look for ignitor in parts search reletivley easy repair
Oct 07, 2009 | KitchenAid Cooktops
One of my kitchenaid cooktop burners does not work
go to searsparts.com could be switch or burner or high temp fuse under glass
Jul 02, 2009 | KitchenAid Cooktops
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
Cooktops Logo
63 people viewed this question
Top KitchenAid Cooktops Experts
vince
davenpdx
Marvin
Marvin
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
