Question about Dishwashers
My Kenmore dishwasher model #66515639000 quit working. It was washing dishes just fine one day and then the next the buttons weren't working properly. The pots & pans button was flashing with the cancel button. After searching on your site, I tried to resent the control panel by pressing the normal wash button and the air dry button 3 times then opening and closing the dishwasher. Now the quick rinse button is flashing. Any ideas of what to do now?
SOURCE: Kenmore Ultra Wash Dishwasher - Blinking Quick Rinse Light
My guess is that the foil that the buttons are mounted to is defective.  The control module "reads" the buttons that are pushed by the fact that the resistance between two pins on the circuitboard becomes zero ie. your pushing the button shorts out two pins.  the foil could have moistire damage or the resiistance of the tracks could be too high.  Solution for both would be to replace the control panel button foil.
Posted on Oct 17, 2007
yalmer
  • 549 Answers
SOURCE: Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Posted on Feb 16, 2008
bigg t
  • 640 Answers
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Posted on Aug 06, 2008
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
heatman101
  • 43501 Answers
SOURCE: Pots, pans, dishes not coming clean, white residue left?
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Jun 22, 2010
Washes fine, NEVER dries the dishes, no matter what is selected.
have you got rinse conditioner in the dispenser- most important
Sep 13, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
May 01, 2009 | Dishwashers
Kenmore elite dishwasher does not dry
one of the buttons on the door will give u heat, just push that button
Apr 19, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore dish washer lights up but will not start wash cycle.
turn off your dishwasher then try it again ok
Feb 27, 2009 | Kenmore Dishwashers
Kenmore ultra wash dishwasher control lock light flashing
Just press the 'Air Dry' button for 5-6 seconds....I have an ancient Kenmore Dishwasher (ULTRA)
Oct 02, 2008 | Kenmore 15899 Built-in Dishwasher
Dishwasher not working again
is the clean light blinking, if so make sure water temp is at least 120 degrees
Jan 02, 2008 | Kenmore 24 in. 15933 Built-in Dishwasher
Buttons don't respond
I have same model, same problem. The appliance repair person came today and said it was caused by a bad touch panel, which is one of the most expensive parts on the dishwasher - around $200 (plus the service call and labor = $340) and must be special ordered and will take about 2 weeks. Sorry. He said that this is a frequent problem on Kenmore dishwashers.
Dec 06, 2006 | Kenmore 16639 Built-in Dishwasher
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Owen Barnes
