Question about Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Calypso is flashing C1 when I try to start a load
  • Whirlpool Master
  • 1,902 Answers
Hello
C1/CI code indicates instantaneous current limit trip. This instantaneous current trip occurs if there is a spike of 26 Amps instantly at the motor windings.This may signify problems with the drive motor, thermal protector or motor controller. Overloading the unit may cause this problem. Press STOP/CANCEL to clear the display. Please get back to me if you have any other questions.
Kevin
Posted on Nov 09, 2010
  • pamelacoven Nov 30, 2010
    The C1 code keep appearing when I do small loads and the cycle stops. Does this need a repairman?
  • Kevin White
    Kevin White Dec 02, 2010
    Pamela, if you think you cannot do this yourself after reading my above solution then yes getting this done by a repairman is recommended.
Problem for Whirlpool Calypso GVW9959K Top Load Washer Kenmore Elite Calypso Wash Motion - I am getting C1 and CA. What steps to I need to do to check out the problems.
The C1 error is displayed when the motor tries to pull more than 26 amps to run.
This indicates a problem with the motor or motor controller.
Overloading or excessive suds can also cause this error.
If you like to make a few more checks then the image below contains the instructions for entering the diagnostic test mode.
Its a short cycle that runs all of the components so the operation of each can be checked.
I hope this helps but an intermittent C1 error can be hard to pin down.
http://media.fotki.com/1_p,wbrrkqqwkwbqsdgxgtqsskgwtqkq,vi/kdkftbfkwxkfsqdgqsg/1/1303472/5961857/image5668img-or.jpg
From the service manual....
"C1 = Average current limit Or Instantaneous current limit.
If a status signal comes back from the motor controller that a current
limit has been breached, the unit will return to standby mode and
display either CA for average current limit trip or Cl for
Average current trip occurs if there is a 2 second average of current
draw greater than 5.55 amps
Instantaneous current trip occurs if there is a spike of 26 amps
This may signify problems with the drive motor, thermal protector, or
motor controller. Over-loading the unit may cause this problem."
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 17, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My kenmore elite calypso has a flashing code C1. What does this mean. Also, how can i get a manual for this washer, that explains all the codes.
C1 is not one of the normal codes. It's probably CI (upper i).
Stands for 'Instantaneous current' limit trip. Happens when there is a spike of 26 Amps intensity at the motor windings.
The manual states it may be a problem with the drive motor, thermal protector or motor controller.
check here for your stuff. make sure you put your exact model number in the box at the top. i used my machine (GVW9959KL1). absolutely awesome website and has very competitive prices, if not the best prices for parts. hope this helps.
-samson39
Aug 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Machine won't work it says C1 message. pls advice.
On Whirlpool Calypso washers that is probably not a "1" but is the letter i. The code "CI" is the fault code that indicates "Instantaneous Current Limit". Instantaneous current trip occurs if there is a spike of 26 amps instantly at the motor windings.
This may signify problems with the drive motor, thermal protector (fuse), or motor controller. Overloading the washer may cause this condition. Press stop/cancel to clear the display. Hope this helped you.
Jul 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite calypso codes a C1 and quite working
Maybe "CL" From User Manual:
“CA” or “CL” (Current Limit)
Is the washer overloaded?
Jul 04, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a whirlpool calypso washer and it is showing an error code of C1, what does this mean and how do I fix it
CI (an "i", not a "one") and OB are related - overloaded, the washer's motor controller will draw too much current and either the average current will peak ("CA" error) or the instantaneous current will spike ("CI" error). OB - out of balance - indicates of course a load that is not balanced, or is too heavy. Wash less items and see if the problems lessen. That is what we have had to start doing, but we still can wash a BUNCH of items in this type washer!
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Press( stop/cancel) to clear the display.
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
C1 code cant find model number on machine to validate service waranty
Whirlpool can get you into a range with your serial number, from there they need features and color.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
C1 Fault
code CL.(C1) This may signify problems with the drive motor, thermal protector, or motor controller. Over-loading the unit may cause this problem. Calypo washers do have a history of break downs within the drive system.
Dec 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
356 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
