Question about Dometic RM2652 Refrigerator
Ever have a solenoid switch go bad - Dometic RM2652 Refrigerator
  • 316 Answers
Solenoids go bad all the time, they are used in water valves, ice dispensers, etc.
Posted on Nov 09, 2010
Honda 300 won't start off the key
The ignition starter switch is a common failure on this model. Have it tested.
Apr 30, 2017 | Honda Cars & Trucks
The dealer replace the time chaim and i put new stater motor and new battery i have problem to start,after 3 or 4 time when i tund the key start
Probably bad ignition switch where the key is. OR the line connecting to the starter solenoid terminal (small). Or could be a bad relay between the ignition switch and the starter solenoid terminal. Could be a bad starter solenoid, Yes, several instances of bad starter solenoids.
Apr 01, 2015 | Cars & Trucks
Suzuki Forenza 2008 Power Door Lock Not Working, I can press it but nothing happened.
if the fuse is good, it can only be 32 things.
the switch to lock it. or the wires to the lock solenoid or the solenoid.
you can find the cause 2 ways,
hotwiring it.
or using a voltmeter.
ill assume you never seen a VM.
jumper the switch, does it solenoid work now?
yes,bad switch,
jumper the solenoid,, work now?
yes, bad wires.
no, bad solenoid.
with meter you can trace the voltage to the solenoid and find the fail point in under 5min, door card off.
i just replaced my solenoid last week, $100 just for the silly part.
im a retired, mech. (electrics, specialist)
Mar 05, 2013 | Suzuki Forenza Cars & Trucks
Turn ignition on but car wont crank..it will start if u turn key on and jump the solenold
The starter solenoid is bad or the ignition switch is bad. Check the solenoid to see if it is getting power. If the solenoid is getting power then the solenoid is bad. But if the solenoid is not getting power with the key in the start position, then the ignition switch is bad.
Feb 28, 2011 | 1998 Pontiac Sunfire
I have a 1990 Harley FLT. When I hit the starter it clicks but won't turn over.Is the solenoid bad or the starter bad.How can you tell which is bad
The solenoid is what makes the starter gear pop out to engage the flywheel to turn the motor. If the solenoid is bad, the starter gear won't pop out. If the starter gear does pop out, then the solenoid is good. The starter motor should turn even if the solenoid is bad.
Jul 26, 2010 | NRS S129 - Starter Solenoid Switch, D984
Stuck in Park - 2001 Honda Accord 4cyc - Automatic
there is a solenoid on the shifter assembly that allows you to depress the button on the shifter to shift from park. this solenoid is controlled by the brake light switch on your brake pedal arm under the dash. you could have a bad brake light switch, bad wiring, or a bad solenoid on the shifter assembly. if your brake lights work properly, the brake light switch should be okay, and you'd start checking wiring to the solenoid. if the wiring tests good then you should replace the solenoid. you may need to buy the entire shifter assembly as most solenoids are not available seperatly.
Dec 19, 2009 | 2001 Honda Accord
My f-150 it will not turn over battery is good but not geting voltaeg to starter help
Use a test light and check at the starter solenoid and see if the ignition start wire gets hot when the key is turned to start. If it does check to see if current then goes thru the solenoid to the starter. If it does check to see if current gets to the starter, if it gets to the starter the starter is bad. If no current to the starter or out of solenoid the solenoid is bad. If current does not get to the solenoid when switch is turned, check and see if the current goes thru the neutral safety switch (Clutch switch if not automatic). If the current doesn't go thru the switch replace the switch. If you are not getting current to the switch in the first place check the ignition switch. If the current doesn't come from the ignition switch to the safety switch replace the ignition switch.
Oct 02, 2009 | 1991 Ford F150
Solinoid not engaging when i turn the key to start i have a new battery also
check battery /cables also check for 12 volts at the solenoid when you are trying to start with key switch . If you have 12 volts at wiring but solenoid wont engage then you have a bad solenoid. If no 12 volts at wiring to solenoid then the problem is between the battery and the ignition switch and or relays to the switch and or a fuse or bad ignition switch !! Good Luck swampratt200
Jul 05, 2009 | 2002 Hyundai Accent
Replaced starter solenoid switch and it still wont crank
this may be a ignition switch see if the little wire going to the solenoid gets power when ignition switch is tried
Jul 02, 2009 | 1992 Mercury Grand Marquis
No power, new battery
Assuming that you didn't just aquire it, it's likely either a faulty solenoid or starter switch. If you just aquired it, it could also be a bad or disconnected seat or brake switch.
To test the solenoid, put a voltmeter between the chassis or battery NEG terminal and the small terminal on the solenoid. Does it have 12V when you try to start it? No? you need to test the start switch and the safety (seat and brake) switches. Yes? Check the voltage on the 2 large terminals on the solenoid. One should have 12V all the time, the other should have 12V when you try to start. Does it? Yes? bad or disconnected starter. No? bad solenoid. Testing the safety switches involves testing the resistance (ohms) of the switch. It should toggle between infinite and around 0 ohms as you actuate the switch. If it doesn't, it's bad.
May 15, 2009 | Briggs & Stratton Garden
Dometic RM2652 Refrigerator Logo
73 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
