Question about Nortel Meridian 9417CW 2 Line phone
Would like line 1 to roll over to line 2 whenever line 1 is busy
Phone quit letting calls roll over to the next line.
Call TELCO that is their problem. That option is set up in the Central Telephone Office.
Aug 21, 2014 | Lands Phones
How to recover data from a rolled back and reformatted hard drive ?
Sorry, no help for you after doing both a roll back and a reformat. This is what has driven professionals to a 3-2-1 backup solution.
3 backups - 2 onsite(two different parts of the house, business) - 1 off-site. Then you can restore from a backup. Otherwise, restore from optical disk or restore partition(if you didn't format it).
Good Luck.
Jul 04, 2014 | Western Digital Computers & Internet
I have attached this cordless to KX-TA824 supporting 2 incoming lines. How can I select which line (CO 1 or CO 2) to call from?
If you start with intercom dial tone, press 81 or 82. If you dial 9 you'll get line 2 before line 1 in normal programming, and if you dial a line that's busy with 8x access codes, you'll get a busy, even if the other line is free.
Of course, you could also RTFM and program the system to function with your TA-824 http://public.carl.airpost.net/Pana/TA-824/UG_TA_0823%5B1%5D.pdf
Starting on page 15 or so of the pdf, after you set up the keys, you'd press the > and 1 or 2 to get to lines 1 or 2 :-)
Carl
Oct 08, 2010 | Panasonic KX-TD7896 Cordless Phone
CALLS NOT ROLLING OVER TO ADDITIONAL LINES
The phone company controls the "HUnt".
If line 1 is busy and will not roll over to line 2, then it is the phone company....
Aug 23, 2010 | Avaya Corded Phone avaparp18d
Norstar 7310 forwards to Voicemail
Sounds like the phone is set for Call Forward Busy/ No Answer instead of Call Forward No Answer. If you cahnge it call forwarding it should work correctly. ....Mike
Aug 08, 2008 | Nortel Norstar 16-Line PBX Speakerphone
M7310
go and edit ur phone settings..its not ur fault it is by the operator..just contact ur gsm operator at call cantre and edit all the settings as he guides u........
Dec 04, 2007 | NorStar M7310 Corded Phone
System Programming, Busy No Answer on an analog fax extension
Programm those 2 extension in memoru 4-14 and 4-15. So when
one is busy rolls over to the second one.
Oct 12, 2007 | NEC Electra Elite 32D-1 Corded Phone
Lands Phones Logo
101 people viewed this question
Top Nortel Lands Phones Experts
Sanjaya Sahu
Sanjaya Sahu
deton8 von Splosion
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
