Question about Craftsman 22 in Hedge Trimmer
What fuel line does the fuel filter go on on the 358796355 Craftsman Hedge Trimmer?
sparksflyin
  • 47 Answers
SOURCE: fuel line replacement
pull the lines off do only one at a time one should stick in the tank 1/4 inch which is your return the second one is your pick up which has a filter in the tank attached to it take a piece of stiff wire or a clothes hanger and bend a tight hook on the end just big enough for the fuel line to fit in it fish the wire in the tank and try to hook the fuel line then pull it out of the tank to take the filter off it might take a few tries but you will get it after that pull the line out from the top not the filter side take the new line and feed it through if you cut a 45 degree angle at the end of the line it makes it easier to feed once you get it in all the way use your piece of wire to hook it through the filler and pull it out then attach your fuel filter then shove it back in the tank like i said it may take you a few times but you will get hope this helps
Posted on Feb 08, 2009
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
riceski
  • 1851 Answers
SOURCE: hedge trimmer broken
Any local repair shop will do this for you - if you're looking for free repair -then please - look at the local sears store to direct you as they have the locations there.
Thanks
Gary @ Fix Ya
Posted on Jun 30, 2010
  • 63 Answers
SOURCE: craftsman hedge trimmer won't start.
Have you changed the H T lead and then check the cut of swicth for faulty wireing
Posted on Jul 24, 2010
bbap
  • 71 Answers
SOURCE: I have a 22inch Craftsman Hedge Trimmer, Model No.
The likely issue is the gear pin has been sheared. The part is no longer available from Craftsman. (P/N from sears: 616255-001)
I had a similar issue with a similar electric trimmer. I removed the old pin and used a split pin and ground it down to the proper size. It's now worked for about 2 years just fine. This requires complete dis-assembly.
Posted on Sep 27, 2010
Fuel line replacement craftsman 22" bushwhacker hedge trimmer
Lines are not sold pre made, you must make it up from bulk fuel line.
May 12, 2017 | Craftsman Garden
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Why does my craftsman bushwacker hedge trimmers not go fast when I have it full throttle?
if engines stumbling when at full throttle , ck to see that your getting full fuel flow ( lots of bubbles in primer bulb are a sure sign of not a good flow) , locate the fuel filter inside fuel tank , ck it for a dark color ? if so replace it , also try adding some normal car fuel system cleaner to your fuel next time u run it for a few minutes , this helps to loosen stuck deposits inside the carb
May 27, 2014 | Craftsman 22" Gas Hedge Trimmer
Need to replace fuel lines on my Troy Bilt gas hedge trimmer. Where can I get replacement fuel lines... or better yet... what size are the lines and where can I buy a few feet of the lines. Note: I...
Replacement fuel lines should be readily available at your local lawnmower repair shop. Your TroyBilt hedger uses fuel line that is 3/32" (2.4mm) interior dimension, 3/16" (4.8mm) outside dimension, with a 3/64" (1.2mm) wall dimension.
Most manufacturers don't offer replacement line, only fuel tank assemblies. Find your local shop, and try to get the TYGON brand...it is yellow. Tygon lasts the longest. You should be able to buy it by the foot for less than $2 per foot. You will need 2 feet of hose to replace both lines.
Make sure to clean the in-tank filter when replacing hoses.
Good luck.
Oct 20, 2010 | Craftsman 22" Gas Hedge Trimmer
Craftsman hedge trimmer won't start.
Jul 19, 2010 | Craftsman 22" Gas Hedge Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Jun 12, 2010 | RTO Weed Eater Hedge Trimmer 20cc,...
Craftsman Hedge Trimmer model 358.796353 that won't operate
The problem you are experiencing is the coil. I had the same problem and confronted a freind that works on small engines. I asked him if the coil could be the problem and he gave me one to try out of another trimmer he had for parts. It is running well. The problem I now have is the blade tang that moves it back and forth broke. Now I'm trying to locate one of them.
Mar 28, 2009 | Craftsman 22" Gas Hedge Trimmer
Jan 25, 2009 | Craftsman 22" Gas Hedge Trimmer
Craftsman 22 in Hedge Trimmer Logo
94 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
john h
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
