WHAT PROBLEM WITH DOUBLE LINE BLACK ON FRONT ,I DONT KNOW WHAT PROBLEM
  • 19,396 Answers
Hi.
If you have black bands at top and bottom or on the side of display, assuming that we are talking about a CRT or rear projection TV, then you have a convergence problem.
The most common fault causing the problem are the convergence ICs.
The repair is done replacing the two integrated circuits whose function is amplifying and stabilizing power to maintain the alignment circuit. Usually more components in alignment circuit must be tested and eventually replaced.
The repair job starts at about $120 up to about $250. The part is generally not expensive (two ICs or transistors and a couple of other components if needed).
Regards.
Ginko.
Posted on Nov 09, 2010
Dont know which wires hook up to positive and which are negative
red - positive switched
yellow - positive constant
black - ground
grey w/ black - right front negative
grey - right front positive
white w/ black - left front negative
white - left front positive
green w/ black - left rear negative
green - left rear positive
purple w/ black - right rear negative
purple - right rear positive
Aug 09, 2011 | Kenwood KDC-422 CD Player
The colors on convergence dont line up I get a green line. blurry double picture on tv ( the red & blue do line but I dont get a white line)
it varies but most of these sets use two of the STK-392-110 CONVERGENCE CHIPS.
BOTH MUST BE replaced and the protect resistors (easy) looked and or tested.
Total parts cost if purchased on EBAY will be under 25 dollars and if you have some talent it can be a do it yourself fix.
Chips are side by side and have the STK number printed on them and are either on two heat sinks with metal fins or one large sink.
I have fixed hundreds of these sets and if I can do it anyone can.
I will attach photo of what typical chips look like and typical convergence problem (no two sets look exactly the same but you will know)
IF THE photos and information told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a comment here and I will assist you.
sd tech
f751396.jpg typical convergence chips
protect resistors for the chips, note the two that are burned or black in the middle--all are low value and a bad one will either be burnt of read like a bad fuse.
Typical convergence problem--most of the time just replacing the chips will cure it.
Aug 22, 2010 | Hitachi 50FX48B 50" Rear Projection...
Windshield wipers dont work
Double check the wiper module which is the black box on the front of the wiper motor. These werw very problematic. They are held on by 3 Torx head screws and the new ones come with the black cover, 3 new screws, and the circuit board. Very easy install.
Feb 16, 2010 | 2000 GMC Jimmy
Dont know if you can help but....I just bought an older model pick up(1989 toyota)it had no radio in the dash, I have a Kenwood CD player i want to install but I dont know the color codes of the wires in...
Nice radio installer link HERE
Check out the lower wiring guide.
A Right Front Speaker (+) Green Gray
B Left Front Speaker (+) Pink White
C +12 Volt Ignition Wire Gray Red
D +12 Volt Battery Wire Blue w/ Yellow Stripe Yellow
E Right Front Speaker (-) Blue Gray w/ Black Stripe
F Left Front Speaker (-) Purple White w/ Black Stripe
G Ground Wire Black Black
H Power Antenna Wire 1 Blue (join wires 1 & 2
I Power Antenna Wire 2 together to this blue wire)
J Do Not Use
K Right Rear Speaker (+) Red Purple
L Left Rear Speaker (+) Black Green
M Right Rear Speaker (-) White Purple w/ Black Stripe
N Do Not Use
O Do Not Use
P Left Rear Speaker (-) Yellow Green w/ Black Stripe
Dec 14, 2009 | Car Audio & Video
How to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
Front panel Mic not working when connected to Mother Board
Yeah,sounds like the case wasn't designed for that board. Just carefully double check the pins in the manual for the board. If you don't have the manual,check the asus site.
Jul 10, 2009 | ASUS Computers & Internet
2001 silverado brake system
I now this sounds weird, but the 3/16 lines to the front wheels are bubble flare and if it has a single 1/4 line to the rear it is standard double flare. If it has 2 3/16 lines to the rear, they will be bubble. They don't bubble flare 1/4 inch line, I don't know why, But they don't. I'm not sure on how many couplings for inspection but as long as you use unions and not compression fittings you should be fine.
May 19, 2009 | 2001 Chevrolet Silverado 1500
I bought the LG LHT854 and i dont know how to connectthe speakers because i dont know which ones are the front speakers and rear speakers, all 4 speakers are the same and i dont know how wich is wich..
All four of the small speakers are identical, the original speaker wires are color coded. the very ends are all black and red, corresponding to the black and red connections on the back of the receiver and on the speaker, and there is another color band lower on the wire, which corresponds to the color on the receiver speaker connectors that details front right, front left, rear right, rear left, center, subwoofer.
If you are using standard speaker wire, it has two colors. Pick one for the red, and one for the black.
Just be consistent and connect all speakers the same at both ends (Copper color to plus-red / silver color to minus-black)
Dec 24, 2008 | LG LHT854 Theater System
Zannusi built in oven
Solid line at top indicates the grill. Two indicate the oven.
Sep 21, 2017 | Zanussi ZHQ575 Electric Double Oven
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
