Question about Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan
All hooked up, fan works, but lights do not there is a wire that says light connection . do I switch them?
    Problem Solver:
  • 5 Answers
The light wire needs to be connected to the hot lead out of the ceiling. If you have only one hot lead (usually a black wire) connect both the fan motor wire and the light wire to this lead. If you have a second hot lead (usually Red) you can connect the light wire separately.
For free troubleshooting advice call The Fan Man 952-898-2754 or 1-866-600-FANS(3267) www.fanmanlighting.com
Posted on Nov 09, 2010
  • juhillo Nov 10, 2010
    The hot wire is connected. All the wires come through the fan rotater with a couplier that hooks to another couplier with the lights. there is one blue wire that has no connector to the lights but has a tag on it that says light connector and two white wires that have the same label on them I tryed connecting them and nothing.......???????????????????????????
  •  Jason Stevens
    Jason Stevens Nov 10, 2010
    If you have followed the blue wire through the fan to the light kit and all connections look normal, this may be a failure of the 190watt limiter. This is a new mandatory component the government has forced on the ceiling fan industry in the last year or so. This device is designed to limit the wattage drawn on a ceiling fan light. I have seen several of these fail causing the lights to be inoperable. It might be possible to bypass this part until a replacement can be located ;)
    If you're still not able to fix this issue, give "The Fan Man" a call. They might be able to help diagnose this problem further for you.
Fan works light don't
Check your bulbs. You should have two light switches, one for the lights and one for the fan. The switch may be broken. If it never worked, then the wire connections are not hooked up for the lights.
Jan 12, 2016 | Dryers
Have dual light switches - one for fan one for lights on fan. incoming to box is white (neutral) black(hot) then out to switches two sets of w/b. fan has one each of the white, black blue(lights). How do...
From your switch box to your fan run a 14/3 wire. Take the incoming 14/2 white wire,and connect to white of the 14/3 wire to fan lite combo ,and hook both white wires from fan and lite. Hook the fan black wire to the black wire from the 14/3 Hook the black wire from the fan to the red wire from the 14/3. Then go back to the switches, and add a black and red pigtail about 4"long to the black wire from the 14/2, now connect the red wire to one side of switch, and the other red wire from the 14/3 to the other side of switch. Do the same to the black wire on the other switch.
Sep 17, 2011 | Garden
House wireing red,white,black. how do i hook up a cealingfan with light kit pull chain on.
For starters, look at the wall switch. Are there two switches? If so, connect the black wire from the ceiling box to the black wire from the fan. Connect the red wire from the ceiling box to the blue wire from the fan. Connect white to white. At the fan, usually the black wire goes to the fan and the blue wire goes the the light.
If there is only one wall switch, you may or may not want to install a double switch so the fan and light can be controlled separately. If there is only one wall switch, most people just connect the wire connected to that switch (usually the black) to both the black and blue from the fan, not using the red at all. In that scenario both the light and the fan are switch at the fan as needed after the wall switch is operated.
Installing the extra red wire is not usual practice, someone actually was planning for future use and convenience.
Apr 16, 2011 | Solar 2-wire Pull Chain Light Switch For...
How do i hook up a two function swith i have white black and ground going to the fan and the light and anther white black and ground coming from my bathroom light i want to have a switch to turn my...
Ok you only have two switches, so you would use one switch for your bathroom light, and the other for both the fan and the light, the light will come on when you turn the fan on.Connect the incoming black (hot) wire to both switches. Then connect the black wire to the switch you want for your light. Connect the other black to the second switch that goes to your fan and light. Connect the three white wires together (neutral) Connect all ground wires together, and leave a pigtail to connect to the ground terminal on the light switch. If you want separate switches for light in the fan and fan, you will need another conductor and a three gang switch.
Oct 17, 2010 | Broan-NuTone Broan 68W Dual Rocker Switch
We just bought a house and the living room has a light fixture and there is a dimmer switch that controls it. I removed the light fixture and installed a ceiling fan but the fan barely moves and the light...
You're correct. The dimmer switch was not made for that fan.
The Green is ground > so you're right there too. I assume other plugs nearby are working when dimmer is on. Check that to make sure.
By your description, I assume there is NOT another switch or dimmer that connects to same light. If so, you need a 3-way switch and the following instructions are void.
I suspect when you wired the new fan, that you saw the red and small black wires in the ceiling box. Did you connect the fan and light to those wires? If so, the following information will help you wire the switch.
Your incoming Hot line is probably the larger black wire that connects to Dimmer black >>> this wire will connect to either screw on the new switch
To test Hot wire for sure: Take out dimmer and mark wires for identification. Separate wires. Turn on power and test each wire to bare ground. Tape tester leads to wood sticks so hands are away from power. You'll be fine. Tester lights up on Hot wire.
Next: The smaller black and a red wires are a toss up.
Here's how I would proceed. Connect the black Hot to either screw on switch. Connect red wire to other screw. Put wire nut over small black. Turn on power. Flip switch. Check both lights and fan to see which works with red wire.
Next reverse the toss up wires. Put wire nut over red. Connect small black to switch. Check both lights and fan.
If red and small black control the light & fan, then connect them together on the same screw, and you're done.
If you want to control the fan and light separately, buy double switch, and then Hot connects to dark-colored screw on one side of switch, and red and small black connect to two different screws on opposite side of switch.
Oct 04, 2010 | Solar 10 Eagle Almond Commercial Double...
When I hook my Hampton Bay ceiling fan to power, neither the fan nor the lights work. I have power to the fan and have the black and blue wires on their own power. I show power to the light socket but no...
OK .. if you hooke the bnlack and blue fan wires to the black and red house wires , then that is set for the hook up .. Now at the switches ,, you should have two switches ,, black on the switch for the fan and red on the switch for the lights .. the switches should both be connected to the hot power wire ,, Check for the neutral connections ,, in the switch box all whites would be connected together , and white to white in the ceiling
Please vote
May 13, 2010 | Hampton Bay 24002 Ceiling Fan
I removed an old fan/light combo from my bathroom and put a new one in. The wiring comes off two switches wired together (3 wires total) and I need to know how to wire to the new fan/light combo. There is...
Hook the black wire from one switch to the fan and the black wire from the other to the light. Then hook all of the white wires together.
This will get you working like you want it too.
Heatman101
Feb 23, 2010 | Kitchen Appliances - Others
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Minka F719 Lavery Wired fan and fan works but light does not come
The light leg should be hooked to a power source. If you have a separate wire from a wall switch, that's where it should be hooked. Otherwise, you can hook it to the fan leg and operate the light from the switch on the fan.
Jan 31, 2010 | Minka F719-TSP Treville Tuscan Patina...
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Hampton Bay 52 In.Carriage House II in Polished and Satin Brass Finish Fan Logo
98 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
