Question about HP Officejet 5600 series
My hp 5600 won't print in color. I set it to only print in grayscale when I ran out of color two months ago. I set it back to color once I purchased the brand new ink cartridge that is hp brand. I did an alignment print out and it print out in blue and black. I also did a test print which includes pressing the * and the # buttons, pressing 1,2,7 and then the right arrow, press o.k. then press the left arrow and o.k. to print vpp report. That print out o.k. But it won't print any documents, web pages, or photos in color? It even makes copies in color. What could be wrong?
  • 3 Answers
SOURCE: black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Posted on Apr 02, 2008
SOURCE: Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
Posted on May 27, 2008
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
joehawthorn
  • 4 Answers
SOURCE: Press enter to align cartrige then I get printing align cartridge page.
Do rhe alignment
Posted on Jun 03, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
I have a MacBook Pro laptop and an HP DeskJet 842C printer. I have been able to successfully print anything that I wanted, in both color and black, up until about 4 months ago. Thinking that my color...
delete the printer from your profiles.
with printer connected via usb, do a software update.
restart computer with connected via usb.
Check with manufacturer to see if there are any new drivers.
Hope this helps
Feb 06, 2014 | Computers & Internet
I have an HP deskjet 5650 and just changed both black and color cartridges. Test sheet ran fine with color and black. Now I am trying to print a Print Shop color document and the printer will only print...
Click Start
Click Control Panel
Click Classic View
Click Printers
Select your printer
Right-mouse click on the icon
Click Properties
Set the printer to print in "colour", not just "black".
Aug 30, 2010 | HP DeskJet 5650 InkJet Printer
Is there any way to get my printer to print only black copies without having to buy the new color print cartridge
Go to the printer settings - Preferences- color tab - and select Grayscale in the color selection.
Once this is done, try print a color text and see if it comes in a gray scale. This will work.
To give you a tip on this.... understand that this printer has a black ink cartridge and a tri-color cartridge. When we select grayscale, only black cartridge would be used.
Good Luck.
Mar 15, 2010 | HP PhotoSmart C4180 All-in-One Color...
Printer will not print
If you go to control panel, printers and fax, right click on your printer, then select properties you will see a section for color or grayscale printing. Select grayscale for all your jobs to be printed in B&W.
Good Luck,
Jesse
Jan 11, 2010 | HP Color LaserJet 3500 Printer
The HP 6300 Officejet printer at my office will print black just fine, but will not print a drop of color. Even the on the test page the color sections are either blank or pale grayscale.
This is one of three problems. The ink cartridge is overfilled, it needs cleaning or alignment, or it is dried out and you need to purchase a new cartridge. If it is dried out, you cannot refill it. The sponge inside is dry and cannot be fixed. Another problem could be in your printer settings. Did you check to make sure that your setting are not on grayscale (black cartridge only). To do this, when you go to print, click File - Print - then click Properties. There should be a tab in that area that will tell you if it is on black ink only. Try to make sure the cartridges are clean and/or replace them. This usually fixes the problem. Cheers.
Oct 02, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Can't print in color on my Canon printer
If you go here you can download or view a manual for your printer, with detailed instructions on changing the print cartridge settings in windows or mac.
If you go here, you'll be taken to the home support page for your printer, where you can enter a search for "print in color", and detailed instructions will follow.
You go to control panel>printers>print preferences> and uncheck the grayscale printing and set the color to auto.
Issue: Image prints black and white instead of color....See below.
Solution: Uncheck Grayscale Printing checkbox (Windows)
Unchecking Grayscale Printing Follow the steps below to change the Grayscale Printing option:
  1. On the Windows desktop, click 'Start', point to 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
    For Windows Vista: Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
  2. Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'. Windows 98/Me: Right-click the printer icon, then click 'Properties'.
  3. On the Main tab, click on the 'Grayscale Printing' check-box to remove the check-mark.
  4. Click the 'OK' button to save the setting.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Color feature is turned off. Need to turn it back on.
Go to Start Menu, Printers and Faxes and right click on the printer, select Printing Preferences, go to color tab, and uncheck print in grayscale
May 16, 2009 | HP DeskJet 5150 InkJet Printer
HP 640 Fax series not printing
If it is a color printer, try printing just grayscale or black& white.  It is is already set to print just b/w, try printing in color.  Basically you may be out of ink.  Run the printer utility to clean the heads and see if anything changes.  A new set of cartridges should fix the problem, I believe.
Hope this helps...
~enov8
Feb 16, 2009 | HP 640 Inkjet Fax Machine
Disable color printing
For your HP 7310xi you have an icon by your clock. Right click on it once & a window will open click Launch/Show. Open printer settings. Another windows will open. Click on the color tab. Under Color Options click to pring in grayscale. The HP will print in balck & white untill you uncheck print in grayscale.
Feb 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Computers & Internet Logo
302 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
