Question about Proline 3238-31 Clear VW Baja Body - MINI REVO
I have a 2006 Baja 50cc Type on plate is (F49-1) Motor casing has (E-22 49cm) I cant get it to spark. I unpluged tether kill switch and still have no spark. Any ideas on how to figure this out?
If I have a icon 50cc pit bike a new coil and new spark plug and c.d.I box light flashes but the thing won't fire and I even changed the kill switch wat could it be
Hi ! for an informantion, please visit the website below. If you need more information about a specific electrical issue you can reach me at motor@motorpartstore.com Motor Part Store Motor Parts Wholesale
Jul 12, 2015 | Motorcycles
2006 Kawasaki KLX 125 Baja Kit wiring diagram
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2006 Kawasaki KLX 125 Baja Kit wiring diagram Google Search
Kawasaki Motorcycle Wiring Diagrams
Kawasaki KLX125 2003 2006 Workshop Repair Service Manual PDF Download... $15
OEM Parts for Kawasaki
Kawasaki KLX125 Owner Manual
May 08, 2015 | 2006 kawasaki KLX 125
How do I wire a tether switch on 1999 700 RMK
You have to put the tether on the incoming hot wire to the ignition. This will kill all power to the ignition. Thus killing the engine. Sorry I can't tell you the color code.
Feb 01, 2015 | Cars & Trucks
Cant get my 50cc scooter to fire up-no spark. any
  • Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the side stand kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Is the handlebar kill switch on? Is it shorted out?
  • Check the fuses.
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires?
  • Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center or side casing.
  • If still no spark, get CDI system and coils checked at the dealers shop.
Aug 14, 2009 | 2005 Suzuki RM-Z 250
My karizma bike will not start....please help
  • Start with a new spark plug. Do you see spark? If not, check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it.
  • Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on?
  • Check the operation of the ignition switch and all kill switches with a volt ohmmeter. Check the wiring harness. Did a wire come unplugged? Are all wires clean and with solid connections? Any abraded or pinched wires? Is the bike in neutral and the neutral light is lit up? If no neutral light, check the neutral switch and neutral switch wire on center casing. If still no spark, get CDI system and coils checked at the dealers shop.
  • Got gas and is it turned on? Clean air filter?
  • Drain the float bowl, it may be filled with water condensation.
  • carb, head and intake manifold mounted tight?
  • Have dealer check the CCVI system (Carb Controlled Variable Ignition).
  • Aug 02, 2009 | 2006 Hero Honda Karizma
    I have a YFM 200 (four wheeler) and am getting no spark. Have changed the plug, it turns over well, where do I go now? I have a 1986 version. Sorry, can't find this under "choose product category", but...
    Check the fuses. Next, check for spark but with a new spark plug. How good is the battery? "Some juice" does not always translate into having enough juice for a spark. Fill the battery cells with water covering the battery plates. Jump start from your car battery. Is the kill switch on? Does the side stand have a kill switch? Is it working properly? Tip-over kill switch on your bike? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
    Please rate this answer. Thanks sharbow!
    Apr 20, 2009 | 2001 Yamaha TW 200
    Wont start
    Check the fuses first. Next, check for spark but with a new spark plug. Is the kill switch on? Does the side stand have a kill switch? Is it working properly? Tip-over kill switch on your bike? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
    Apr 14, 2009 | 2006 Motorhispania Arena 125 Pro Racing...
    05 crf 450 with No Spark
    remove the front number plate and inspect the cdi box, look 4 damage 2 the case then check wiring connectors-should a 4wire and a 6wire block.also check LH engine casing 4 damage (gear lever can smash it if u crash) this is where the stator coil is-which is the power source 4 the ignition system. hope this helps.good luck.
    Apr 06, 2009 | 2005 Honda CRF 450 R
    Won't start after pulling safety tether Polaris Predator 90 2006
    as long as the tether is back in correctly it should start. try checking the battery. if the battery is fine then look at the battry and make sure your tether wires arent shorted anywhere
    Apr 02, 2009 | Polaris ATV
    Proline 3238-31 Clear VW Baja Body - MINI REVO Logo
    121 people viewed this question
    Top Proline Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Proline Air Tool and Compressor Expert? Answer questions, earn points and help others
