Question about Breadman TR444 Bread Maker
Instructions ,for quigg b read makeing machine md 12830
C13 read error
Your MD cannot read the disc for some reason - bad disc, dirt on your player laser, dist in the MD casette or worn out or damage laser head in the machine.
Try another disc if no problem it is the disc - if same problem air dust the head lightly if still a problem likely damaged or worn out laser head (this is a mechanical device which wears out in time)
Feb 17, 2014 | Audio Players & Recorders
I lost the userguide of my quigg ultrasonic cleaner, type SR 630.09. And i want to clean my watch and jewelry. Can anybody help me use this machine.
This Manual will give you the Information to get it working correctly again... Good Luck
http://www.manualswall.com/results.php?lang=en&search=MICRO+ONDE+QUIGG+MD+12801+USERS+GUIDE#.UWMt8VeRfAI
Apr 08, 2013 | Watches
I need a manual in English for the Quigg Breadmaker, MD12830
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 19, 2011 | Microwave Ovens
Sony cmt-cp33md,place dic in machine,toc reading shows read error C13,then ejects disc.
The c13 error means that the player is unable to read the table of contents (TOC) on discs any more. If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
On the plus side, there are millions of MD units now lying unused as folks have moved on from them and as they're mostly worthless people don't generally bother with trying to sell them. Almost every piece of MD gear I own has come free of charge via my local FreeCycle and Freegle groups. Whatever you do, don't buy a used player from anyone: they're all getting on now and the TOC error is an age-related fault which may occur at any time.
If you wish to see exactly what features other machines have then visit the superb equipment browser at minidisc.org. The site is hosted but n longer maintained though so some information is out of date, but it's still the most comprehensive source of free information about MD available.
Sorry here's probably no hope for your player, but I hope that my reply has given you a practical alternative means of solving your problem.
Sep 06, 2010 | Sony CMT-CP33MD CD Shelf System
I have Sony md player/recorder,model is MDS-E10. it play correctly but the problem is at recording,once yuo put the recordable empty md and you comand it to record it do not record any thing why the source...
Minidisk systems encode music diffferently than CD's do. The instruction manual for your model can be found at http://www.minidisc.org/sony_mdse10_manual.pdf you will need to reference page 18 for instructions and trouble shooting.
May 06, 2010 | Sony MDS-E10 Mini Disc Player
I have a problem with my MD player.on screen showing read error c13.is it easy to fix?
The error means that the player is unable to read the table of contents (TOC) on discs any more.If it's an occasional error then you can try switching to TDK blanks as they seem to be easier for flaky players to read, but if it's happening regularly to all discs then your machine is unrepairable due to a total lack of spare parts.
Mar 16, 2010 | Sony CMT-M100MD\W CD Shelf System
AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Breadman TR444 Bread Maker Logo
951 people viewed this question
Top Breadman Kitchen Appliances - Others Experts
Dave Kristol
Level 1 Expert
Irene Tulloch
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
