Question about GE (PSS26MSRSS) Side by Side Refrigerator
Overfreezing dampener was replaced and it wont open and close when it should.
  • 54 Answers
The damper will close when door is opened and will open when the door is closed and the refrigerator needs to cool off
Posted on Jul 03, 2008
Wont stay runin
air cleaner intake is clogged or dampened closed by the map sensor
Oct 21, 2014 | Cars & Trucks
Why does my dash air blow hot air
There is a dampener that opens and closes inside the duct system under the dash. If it gets stuck on the wrong position it will blow hot. They are usually vacuum controlled. Try to slide the thermostat to hot then back to cold and see if it will actuate. If not, you will need to locate the dampener and check the actuator for failure.
Jun 11, 2014 | Forest River RVs
Ffa47x fridge not cooling freezer overfreezing
there is a little air passage that allows the cold air form the freezer to cool the refrigerator is blocked or jammed closed check that first then you can get back to me
Dec 30, 2011 | Hotpoint Refrigerators
OUR HEATING BILL WAS 215.00 IN PHOENIX! GAS COMPANY SAID CLOSE THE DAMPER AS WE ARE HEATING UP SUN CITY. WHERE IS THE DAMPER ON A MASTER COOL. IS THIS CORRECT --WHY WE HAVE THIS HIGH OF A BILL?
If you have a dampener, its source is outside air The dampener is located in the return air line and could be as small as 3/8" wide and 2" long. Sometimes it is concealed by the insulative overwrap of the return air. Look for where the return line has a junction to a transition. If the dampener handle is parallel to the return line, it is open. move it to the perpendicular position and it will be closed. If its open, you're drawing in outside air to be heated up.
Jan 26, 2011 | Mastercool 67680 Evaporative Cooler Air...
In my 99 beelte the rear hatch will not open. (not with the button on the door or with the key) When I bought the car about 3 weeks ago I was only given the "Valet Key". is there a "valet...
Welcome to FIxYa.com
the fuel door and trunk release should be in one panel on door.
Too there is a relay that may have gone bad.
Check relay and all fuses
Check fuse with test light
550604 tech #
Jun. 5, 2006
2O1l907l
Condition
Customer States Rear Decklid. Hard to Close
Customer states rear deck lid not closing properly.
Technical Background
Due to the stiffness of the original lock dampening rubber, the rear deck lid may be
Difficult hard to close.
Production Solution
A new lock dampening rubber was incorporated into production during calendar week
(CW) 4405. beginning ith VIN: IC_6M407025.
Service
Install improved lock dampening rubber Part No. lCO 827 589 B:
Open rear deck lid.
A Remove rear decked trim panel (see Repair Manual, Body Interior, Group 70- Interior
Remove Lock housing cover.
Tip:
To remove lock housing cover, gently pry between the locking pawl and cover guides
while pulling down on cover. Underside of cover shown for case of location identification.
A Remove the lock dampening rubber by pulling downward out of lock housing.
Install new rear lock dampening rubber Part No. lCO 827 589 B.
Tip:
Ensure proper engagement of lock dampening rubber retaining tab into the lock housing
and is seated on the guide slots.
A Install lock housing cover.
A Install rear deck lid trim panel (see Repair Manual, Body Interior, Group 70- Interior
Thank you for using FixYa.com
Regards, Lee Davidian
Nov 18, 2010 | 1999 Volkswagen Beetle
Food coming out of freezer covered in ice overfreezing
have your themostastic control replaced (stop wasting money)
Sep 13, 2010 | Whirlpool Upright Freezer EV161NZRQ
HP Officejet 6480 leaves a black line down left side of sheet only when usine document feeder. Already cleaned feeder rollers and feeder glass, as well as glass bed.
I found the following information on the HP web site, under their support forum.
Clean the automatic document feeder (ADF)
If the product is not already off, press the Power button to turn off the product, and disconnect the power cord from the product.
Remove all originals from the document feeder tray.
Open the ADF cover.
Lightly dampen a clean, soft, lint-free cloth with distilled water, and then squeeze any excess liquid from the cloth.
Use the damp cloth to wipe any residue off the rollers and separator pad.
NOTE: If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
Close the ADF cover.
Step 2: Clean the glass strip in the ADF
Open the ADF cover, and lift the ADF mechanism.
Lightly dampen a clean, soft, lint-free cloth with a mild glass cleaner.
Gently clean the glass strip inside the ADF, and then thoroughly dry it to prevent spotting.
Lower the ADF mechanism, and close the ADF cover
Close the scanner lid, reconnect the power cord to the product, and then press the Power button to turn on the product
Aug 23, 2010 | HP Office Equipment & Supplies
Feeder wont grab sheets
open the cover of the document feeder you there will find two rollers (blue and grey) clean these rollers with a cloth dampened with nail polish remover
Oct 06, 2009 | HP Laserjet M2727nf Multifunction Printer
Freezers too cold leaks h2o to fridge now fridge wont cool
because of too less gas in the system it cant make cool enough too switch off the compressor
May 10, 2009 | Refrigerators
Frost in freezer
YOU NEED TO CHECK IF THE DAMPER CONTROL IS NOT CLOSED SHUT THAT CAN BE THE REASON FOR THE FRIDGE NOT COOLING.YOU MIGHT NEED THE ASSISTANCE OF A REPAIR MAN TO ASSIST YOU.
GOOD LUCK.
MOHAMED
Sep 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE (PSS26MSRSS) Side by Side Refrigerator Logo
111 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
