Question about Refrigerators
Drain pipe is block. how do I clean it. - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 09, 2010
MY washer fills, sometimes stops without completing the wash, sometimes it shows a completed cycle but the clothes are too wet to dry, sometimes during a cycle it will turn off with the door locked.
Sounds like a draining problem - Check the drain filter isnt blocked, if fitted before doing anything else - remove the filter and clean it. Then, can you hear the drain pump running on the drain cycle (drum not moving but pump should be) - a chug chug chug noise and water should be flowing down the waste pipe. Door WILL lock if the machine is full of water or is slow to drain - to prevent floods. Do NOT force the door open without draining - you will only break the door handle.
If water not flowing on drain - and filter clear - may be blocked pipe, sock stuck in sump hose - coin or counter flipped on edge in a pipe and blocking it - something like any of the above. Clothes too wet to dry is classic partially blocked drain pipe symptom - or spin aborted as drum out of balance.
Feb 01, 2018 | Washing Machines
My washer drains to fast it overflows my drain
use a drain cleaning product to clean the blocked drain or get in a plumber to do the job
it is not a problem from the washer but of drain maintenance
Oct 22, 2017 | Washing Machines
Zanussi 1250 washing machine FLS 1383 W does not drain
Sump hose probably blocked. Tilt washer backwards so u can get under it. Pipe comes from bottom of tub too filter housing, squeeze it you will be able too feel if anything is stuck inside it, simply remove pipe at one end and remove blockage.refit pipe and test
Jun 20, 2013 | Zanussi Washing Machines
Bosch 1200 washing machine will not drain the water ??
The filter or pump is probably blocked, have you tried cleaning it out.
Sometimes if the outlet hose is blocked or kinked this can also be the cause.
Dec 13, 2010 | Washing Machines
Is there a lint filter I can clean in the Whirlpool Duet? I have water come up out of the drain pipe when it empties. I already put drain cleaner down the pipe but water still comes out sometimes. is there...
its your drain pipe thats blocked up,, i take it its the one that the washer is pushed into and go's out the wall to the drain that the water is coming back up from,,,in all sope powders there mostly made from a "clay base" so the out let pipe is blocked with "clay wast" push a cleaning rod down the outlet on the wall,,,down to the drain to clear it out its not likley to be the washer thats blocked up,
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sink drain slow
You can purchase a device from Home Depot that will clean out the drain. In the plumbing business, we call it a blow bag. But some call it drain dog and so on. It's a black rubber bag that fills with water and then when it reaches a certain pressure it blocks the drain but runs water through it until the clog is dislodged. You attach it to a water hose and push it into the drain as far as you can get it. Run it for 15 to 20 min. and then pull it back out. There are several sizes to accomadate the pipe size. You sill need the one that does pipes up to 2 inches. You will have to remove your drain assymbly under the sink to do this. While you have the drain assymbly off, you can make sure it is clean as well. This will clean out the garbage that collects in the pipe. Hope this helps.
Mar 20, 2009 | NRS A.H. Undermount Large and Medium...
Freezer does not drain water to pan
Your drain pipes blocked,i suggest you flush it clean.Look at the back where the drain pipe comes out,you can even blow it out,just make sure you clean it properly.
Regards.
Wouter.
Sep 11, 2008 | Frigidaire Refrigerators
05 susuki forenza
Removal Procedure
1. Disconnect the negative battery cable.
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
the exhaust manifold.
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Jun 14, 2008 | 2005 Suzuki Forenza
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
