Scanner error 20 in hp laser jet m1319f - Office Equipment & Supplies
  • 857 Answers
HP Printer Error Code 20 is a very common error on HP printers, which will show when your printer does not have the correct settings / configuration to enable it to be used properly. The error will generally show when you try and print a document on your HP printer, and will claim that the "Printer Is Not Activated". Although there are multiple causes of this specific error, the good news is that it is very easy to fix if you know what to do.
The error you're seeing will typically show like this:
•"Printer not activated - Error code 20′
The reason for HP Printer Error 20 to show is mainly down to the way in which Windows is continually trying to use the printer, and does not have the right settings / options for it. Printing a document with an HP Printer Error 20 is actually quite a feat, and your PC needs to have your printer set up in just the right way in order to achieve that.
Fortunately, there's a very simple and effective way to repair the Printer Error 20 in the most effective way possible - by using the steps outlined in this article.
The way to fix Printer Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. To make sure this problem is not an issue, you should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
After setting your HP Printer to be the default printing device for your system, you should then look to reinstall the printer on your PC to prevent Error 20.
You can do this by clicking onto "Device Manager" and then removing the printer from your system. On top of that, you should also look to remove any third party HP printer driver software from your PC, and install it again after a restart.
-Finally, you should also use a registry cleaner tool to fix the HP Printer Error 20. Registry cleaners are software tools which can fix any of the damaged settings and errors that your system might have inside. These tools are highly popular, and are used by 1,000's of people every day to help fix a variety of errors on your system. One of the biggest problems facing the HP Printer error 20 is the way in which many people's computers will actually have an incorrect file / setting inside the registry that's leading the error to show. To ensure this problem does not cause your system to become damaged, you should make sure that you can fix any registry errors Windows has.
Or the error may come like this :
Error code 20 Problem: "Not Enough Disk Space" error message
Possible Cause: Your computer needs free disk space to complete a print job. The amount of disk space required depends on the size of the file you're printing.
Solutions:
•A large print job has exceeded the memory capacity of the printer. Verify that the SIMMS or memory cards are seated. Add more memory or simplify the print job. Remember the original HP Laserjet has only 128K of memory available, the LJ+ has only 512K and neither one is really upgradable.
•On the 5P turn the image adapt and page protect to ON or AUTO. These can be set within the Remote Control Panel. Press GO to resume printing.
•On the 5L, set the Enhanced I/O to AUTO (PCL mode) and resend the print job
•Windows XP, click Start and then click Control Panel. Click Printers And Other Hardware and Printers And Faxes. In the Printers And Faxes window, from the File menu, click Server Properties, then click the Drivers tab. This shows the settings in your printer's driver. Compare the settings in this dialog box with the ideal settings in your printer's manual. If you see a discrepancy in these settings, the printer may simply need a new driver and delete old one. You can download printer drivers from the printer manufacturer's Web site.
• Get more help. Installing a new driver won't solve every printer woe, of course, so understanding printer's manual and Windows' built-in Help system will give you an even sharper troubleshooting edge.
Posted on Nov 09, 2010
2 Suggested Answers
MUKHTAR
  • 2017 Answers
SOURCE: HP LASer jet m1319f mfp errors no entries in fax
kindly re install the printer driver software .
Posted on Jan 14, 2010
How to scan a document using hp laser jet?
Hi!
You can follow the linkd follow below, it will detail you how to scan document using HP Laser Jet:
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?locale=de_DE&taskId=115&prodSeriesId=378052&prodTypeId=18972&objectID=c00063830
http://www.ehow.com/how_6939172_scan-document-hp-laserjet-3200.html
Hope this helps.
Apr 18, 2011 | HP Laserjet M1319F Laser Multifunction...
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
HP Laser Jet 3055 printer-52 scanner error?
Remove the top cover. The laser / unit is a black box.
Try www.partsurfer.hp.com
to purchase one.
Jan 15, 2010 | Office Equipment & Supplies
HP LASer jet m1319f mfp errors no entries in fax log
check that it is connected to the phone line, if your phone line is working your fax system also work
Jan 07, 2010 | HP Laserjet M1319F Laser Multifunction...
HP Laser Jet 3030 not work
remove scanner glass and use compressed air to blow out the scanner
Sep 23, 2009 | HP LaserJet 3030 All-In-One Printer
Scanner error
You will have to replace the scanner assembly.
HP Part # C9124-60103
This replacement shoult take 20 minutes.
Jan 01, 2009 | HP LaserJet 3330 All-In-One Printer
1,598 people viewed this question
k24674
