Question about ASUS Eee PC 1000HE Netbook
I have the same problem but does not have a sd card can a flash drive be used in the same way as the sd card
  • 74 Answers
First, A netbook that use SD card doesn't same with the SD card at your hard. Second if you wish to make your SD card bootable, you need to make it a bootable. You may try to google on how to make a bootable USB pendrive. You may use the step to make your flash drive boot in the same way as the SD card in your netbook
Posted on Nov 09, 2010
.Can not take pictures at night with my Moultrie 1100i trail cam. I was informed that there are numerous SD cards that should not be used.
Not being able to take pictures _at night_ likely has nothing to do with your SD card. If the SD card works during the day, it should be fine at night, too.
Any camera needs some light to take pictures. Many use flash to take night time pictures, or infra-red (IR) lighting. I don't know your camera well enough to know if you have either or how to configure how to turn that on.
Nov 11, 2015 | Max Electronics - Others
Where is a tutorial to learn how to load micro sd cards and flash drives for tablet use?
http://www.howtogeek.com/201980/how-to-mount-a-flash-drive-on-your-android-device/
Apr 01, 2015 | Coby Kyros MID8120-4G 8" 4 GB Tablet -...
My handphone cant read sandisk micro sd.. how to recover it?
You can connect the sd card to computer with a card reader, then you can follow this sd card recovery guide to recover your files
SD Card data recovery guide
After you get back your files, you can format the card and try to use it on phone.
Jan 26, 2013 | SanDisk 2GB microSD Memory Card
How do i repair sandisk micro sd card
Hi....
If you lost your data from sandisk memory card then you can use one of the sandisk memory card recovery software that is available online in order to recover files from sandisk memory card.
Dec 06, 2012 | Samsung 8gb Micro Sd Memory Card 4 Galaxy...
Transfer pictures to a flash drive
From the memory of your camera which is a SD card you must transfer using the linking cable to your PC or by inserting the SD card to the card reader on the PC. Now transfer the images to a marked folder and then connect the flash drive, now copy the folder to your flash drive. Using copy and paste or send it to the flash drive using right click .
Jul 23, 2011 | Cameras
My flash dik is write protected
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Can I use PEN DRIVE or SD CARD for my N364 instead of Floppy Drive? If yes, then how to do it?
You can get the SD Flash card and get the little usb device that you can slip it into that will allow it to essentially be a flash drive and have the best of both worlds...something like this... http://www.sourcingmap.com/sdmmc-8in1-me…
So for like 8 bucks extra you have both a thumb drive and an SD Card. If anything goes wrong with the circuitry in the reader you just get another one. The expensive part is the flash chip. When you have it embedded on the thumb drive and the circuitry on the thumb drive goes...there really is no way for you to salvage the flash chip even if there is nothing wrong with it. Unless you are an electronics expert like me, of course.
Technically speaking they are pretty much the same. There is a little more circuitry that goes into a flash drive. It is the EEPROM and the reader and a light with the usb connector all on one PCB. The SD Card is pretty much just a EEPROM with some leads on it. There is less to go wrong with the SD Card.
I hope you realize that after a while your flash drive and sd card will stop working eventually. It is inevitable.
A flash drive or sd card will last for around 100,000 read/write cycles, so it directly depends on its usage, not necessarilly time...it could conceivably be usable 50+ years from now. However, if you are using it 24/7 as you might a normal hard drive it will only last you a couple years. And, of course, this is barring manufacturer defect and damage, be it physical or environmental.
If I were you I would get a bunch of the cheaper 2 GB SD Cards and put different mixes on each one. This way you do not have all your eggs in one basket. It will not be nearly as expensive if one fails and it will not be as big a heart break if someone steals it or you lose it. It will cost you a few dollars more to get 16 2 GB SD Cards but I think the trade off is worth it.
It will be kinda cool to have a little SD Card case with a bunch of SD Cards with labels on them for your favorite mixes...don't you think?
It's what I would do Do you realize how many songs you can fit on a 2 GB stick? You definately wont be swapping them out every stop light...that much is for sure.
Jan 19, 2010 | Korg TR76 76 Key Synthesizer Workstation
Transfer from usb to micro sd
This mp3 player does not appear to have SD card support. In general terms, however, if you plugged a USB flash drive into one USB port of your computer, and then plugged an SD card into the SD card slot on your computer, you can then double-click "My Computer," and then double-click on "Removable Drive F" or whatever your computer is calling the USB flash drive. Then, open a second instance of "My Computer," double-click on the SD Card logo, and then drag files from the USB flash window, or to the SD card window as appropriate.
Another way to do this without opening a second instance of "My Computer," would be to open up the icon for the USB flash drive, right-click on the first file that you want to transfer, and then select "Explore." The window will then change - you will see the file or files you want to transfer on the right, and all available drives (including the SD card icon) on the left. Drag and drop from there.
-Tha Mp3 Doctor
Dec 28, 2008 | RCA OPAL M4001 MP3 Player
Delete some foto on SD card
Using a Photo Recovery software is your best bet!..Adroit Photo Recovery worked very well for me - Try http://digital-assembly.com/products/adroit-photo-recovery/ Hope this helps
Aug 10, 2008 | Cameras
ASUS Eee PC 1000HE Netbook Logo
164 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
