Question about Belling 351 Electric Kitchen Range
Can't make clock work on Belling range 900 classic
How do i set the clock on db900df belling
Assuming that this is a new unit, the supplied manual will have the correct procedure. (RTFM). If you don't have it, you can perhaps find it here. Good luck.
http://content.etilize.com/Manufacturer-Brochure/1028052294.pdf
Feb 02, 2015 | Belling DB4 90EI Gloss Black 900 mm...
I have an old belling farmhouse cooker the hob works fine but the oven isn't igniting manually or by the electric ignition The timer is manual and is stuck on the red patch I can't seem to shift it ...
Take the tiny screws of there are loads down right hand side then release screws on hob once you can lift hob plates up. Undo the covers on back of timer clock control . Make sure you un plug from mains . Take the neutral of back of timer clock. This will allow your oven to auto ignite again
Jan 07, 2014 | Belling FarmHouse 931 Gas Kitchen Range
Main oven not working. Clock is flashing with all zeros & Auto. Please advise, thank you
hello - I have just had an engineer out to fix this on mine and it is as simple as you have to have the clock showing a time!
Jan 30, 2011 | Belling DB2 Dual Fuel (Electric and Gas)...
Ignitor not working????
try cleaning them with steel wool first they could just be dirty
May 15, 2010 | Belling CookCenter 151 Dual Fuel (Electric...
Could someone tell me where to download a user manual for the belling db90,i cant remember how to set the clock!thanks
I have just been able to get hold of my Aunt & Uncles manual and have quickly uploaded a pdf version to my website - 2.79mb - here is the link, hope this will help you all -
http://www.pierrequevatre.com/Belling_db90_Electric_Cooker.pdf
Jan 22, 2010 | Belling DB90 Electric Kitchen Range
Old belling classic cooker,oven door catch has
my oven done the same so i bought some strong magnets and put one in each corner.
its fine now.
Sep 03, 2009 | Belling 644 Electric Kitchen Range
Main ovens dont work
if the clock is not set the ovens wont work,they dont have to say the right time but they do have to have a time. to set the clock hold the hand button and the clock button(first two buttons),and then plus or minus to set the time
Dec 12, 2008 | Belling DB90 Electric Kitchen Range
HOW DO I SET THE CLOCK ON A BELLING MUTI-FUNCTION OVEN. MODEL NUMBER XOU179
press clock..enter the time, press enter, then clock again..should flash..after 5 seconds
May 28, 2008 | Belling Kitchen Ranges
Belling 351 Electric Kitchen Range Logo
46 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
