Question about Konica Minolta Bizhub c203 Copier
We have a Konica C203 printer. The right side door wont open. The release lever won't open door. Is there a way to take the door apart to get to the release lever.
    New Friend:
  • Konica Minolta Expert
  • 118 Answers
Yes the right side of the door on the bottom there is a spring loaded hinge you may be able to push it in to remove the door
Posted on Nov 29, 2011
How di get 1999 mercury mountaineer driver side door open lock wont release
You will need to take the inside panel off to see what has come apart, broken or is binding.
Jan 10, 2015 | Mercury Cars & Trucks
Konica 7075 paper drawers wont open
The 7075 uses a solenoid interlock on all the drawers. The machine must be powered up and not have a jam indicated between the drawer and machine main body. It also will only allow one drawer to be open at a time. There is a manual release lever on the left side of each drawer. The lever is accessible by opening the long, skinny left front door.
Apr 04, 2014 | Konica 7075 All-In-One Laser Printer
Error code 4553
Yellow LASER is bad, try a reset open close right side door. if it comes back need to have the printhead for yellow replaced
Jan 23, 2014 | Konica Minolta Bizhub c203 Copier
Blad c4151 minolta c203
Cyan (Blue) print head failure, need to be replaced, open close right door to reset
Jan 18, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
My knocia 7222 is always jamming it says open right side cover release lever 1 and remover paper open conveyance cover 6 fix guide 5 during depress fix guide 9 remove paper the paper always get stuck by no...
close right side cover is showing on the screen display but door is closed i have already replaced the door switch and power supply board and main mother board and tray control board.kindly advise what can i do to remove (close right side cover) sin?
Tariq E-Tech E-Mail : e_tech_pk @hotmail.com
cell : 03455235670.
Mar 15, 2013 | Konica Minolta Minolta 7222 Laser Printer...
I got an error code 2556 on my c203.please help
Very very common issue... did you clear it yet?? if not to clear it open and close frount door. then to fix issue change toner.... if that doesnt do it try running something with lots of yellow on it... the code means there is too much yellow toner in the image unit... if that wont work then replace yellow image unit.OH you may want to clean the belt sencors too its super easy i can help if needed
Sep 21, 2011 | Konica Minolta Bizhub c203 Copier
Hi, Our Konica Minolta printer c203 with reserved dynamic ip address in dhcp (windows server 2008 r2) won't print. Should I assign a static ip address? Kevin
it will be easier to set the copier up with a static ip. then the server can find it easier. to do this go into admin mode and change it.
Sep 20, 2011 | Konica Minolta Bizhub c203 Copier
I have bought a image transfer belt. I need to know how to access area where belt is located. Do I need to be careful in handling new belt
open right door (the door used to remove jam. there are 2 silver levers that have screws holding them down just under the fuser unit. remove the screws and that will release the belt. it wil slide out easily . then replace it. unfortuneatley you did not have to replace it unless it was dammaged... there is a small pico fuse in it that you can replace for like 2 dollars that will reset the counter... if you have more questions drop me a line
Aug 02, 2011 | Konica Minolta Bizhub c203 Copier
How do you install a new transfer belt for the MagicColor #7450 printer?
Hi there !
The transfer belt is located at the right side of the printer. First you have to remove all the cartridge because the transfer belt is on the bottom of that printer. Open the right door of the printer and there is lock on both sides to free release the door cover and then there is a lever to unlock the transfer belt and pull it out to remove the transfer belt.
I hope it helps you.
Feb 09, 2011 | Konica Minolta magicolor 7450 Laser...
Konica 7222 f28-3 code
part # for the t/s unit is 40la-2600. if you need it I can order the part for you
Aug 13, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub c203 Copier Logo
121 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
