Question about Technics SA-TX50 Receiver
Unit comes on ,work and shuts off. Comes on again ,work for a while and shuts off.
    Novelist:
  • 87 Answers
This is a common question on this site. Amps of all types have protection circuits to keep them from doing a self meltdown. Testing follows this logic. 1. Remove all speaker wires. 2. Keep the volume down - all the way. 3. Turn the unit on. 4. If it does not trip off, then there is a problem either in a speaker or the wiring. a. Reconnect one at a time until/unless it trips off b. That will tell you where to look further.
If it does trip off, then there is an internal circuit issue in the amp and probably requires professional help to fix.
Posted on Nov 10, 2010
While mowing along my blades stopped turning. i shut the pto off and tried again. i noticed the battery light comes on when i turn the pto on. i let the machine cool off and tried again. the pto turns on...
Did it work right after you changed battery? It sounds like your regulator/rectifier isn't recharging your battery. When the battery isn't charging properly the pto wont work for long. If you have a multimeter, hook it up to battery while unit is running and check voltage on battery. When idle is high you should see more charge and vice versa. Please exercise caution when doing this. Hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Aug 01, 2013 | Garden
My outside condensing unit on my central air unit shuts dow when my thermostat is still calling for cold air. I have to shut down stat and breaker to unit and re start after an hour or so and the the unit...
My first guess is a dirty outdoor coil would give same symptoms you are having, high head pressure caused by the lack of air flow thru the coil, preventing proper heat rejection.
Jul 11, 2011 | Heating & Cooling
UNIT WILL SHUT ITSELF OFF WHEN IN USE SOMETIMES AFTER 10 MINS SOMETIMES TURN BACK ON AND IT WORKS AGAIN SOMETIMES WON'T COME BACK UP FOR A COUPLE OF HOURS
I suspect that the power supply is not making a proper connection and comes loose in the socket, the gps unit then is forced to use battery power but since the battery is not fully charged yet when the battery power is to low the unit shuts down and will stay down till enough of a charge or the power supply gets bumped and makes a solid connection again.
Jun 11, 2010 | Garmin nuvi 260W GPS Receiver
My compressor shuts off after a few minutes
Hello
One possibilty is the out side coils or condenser is dirty.And the unit is shutting down on high heat.
Try cleaning the outside coils with some simple green cleaner or even comet spray, then rinse with a hose.
May 27, 2010 | Frigidaire FAS296R2A Air Conditioner
Auto shut off comes on instantly
TURN UNIT OFF.. MAKE SURE DEHUMIDIFIER HAS NOT BEEN RUN FOR AT LEAST FIFTEEN MINUTES... TAKE BUCKET OUT... HOLD IN THE BUTTON THAT THE FLOAT IN THE BUCKET PUSHES ON.. THEN TURN ON THE UNIT.. DO NOT LET GO OF THE BUTTON EVEN A LITTLE BIT IF YOU DO YOU WILL HAVE TO WAIT FIFTEEN MINUTES AND TRY AGAIN.. IF UNIT WORKS THEN YOUR FLOAT IN THE BUCKET IS THE PROBLEM...
May 07, 2010 | Goldstar DH304 Dehumidifier
Unit shuts off slam door or hit unit and it comes
Replace the thermostat , and that will guarantee , to fix the problem . Where the temp is adjusted .
Dec 22, 2009 | Refrigerators
Aiwa compact disc /2disc player
Same problem here...I determined that if you unplug the receiver for a few hours, it will work again for a week or so.  Someone else on this website said that it had something to do with the power relay switch:
http://www.fixya.com/support/t190750-aiwa_av_dv75_powers_off
Aug 04, 2007 | Aiwa AV-DV75
Open Questions:
See all Technics SA-TX50 Receiver Questions
134 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
