Question about 1401 Remote Start/Keyless Entry System
Have a mazda 6 GS 2010. When I use the starter in the street, I have no problem. When I park in my drive-way and use the starter, it rings. Why?
  • Alan H Nov 09, 2010
    Please explain what you mean by "it rings."
  • smiccoli Nov 11, 2010
    Instead of the car starting, the car factory alarm goes on.
  • 139 Answers
I cannot tell you why the factory alarm is triggering at one place and not the other but I can tell you that the remote starter is not disarming the factory alarm.
In order to disarm the factory alarm, the remote starter must supply a ground pulse to the disarm wire at the body control module (BCM). The BCM is located in the driver side kick panel and the wire is black in pin "L." To arm the factory alarm, the same wire needs a ground pulse through a 1k ohm resistor.
I have not installed the 1401, so I am not sure if that particular unit has outputs for factory arm and disarm, most DEI products do have at least a disarm wire that is light green/black. This wire outputs a negative pulse that should disarm the alarm without the addition of relays. If 1401 is equipped with a alarm rearm wire it would most likely be green/white. This wire also outputs a negative pulse but it will not be sufficient in rearming through a 1k ohm resistor without a relay. The relay terminal would be wired as follows if the 1401 is capable of this feature:
30 = vehicle black wire (solder in 1k ohm resistor)
87 = chassis ground
87a = no connection
85 = green/white wire of 1401
86 = 12v constant (fused - 5A is more than enough)
Posted on Nov 12, 2010
The parking brake/low brake fluid light is on but the parking brake is not on and the brake fluid is full
One of the sensors has gone bad or is disconnected. Either the parking brake handle or the fluid level sensor.
Sep 02, 2016 | 2010 Mazda 6 2.5
2010 flhx starer drive problem
Hi, Marcil_dan for this scenario you will need a service/owners manual if you can not find the first and best tool you ever bought for your Harley, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
2005 Harley Dyna FXDX starter replacement
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief A must have !!! only $6 a month "CHEAP"
Jun 26, 2016 | 2010 Harley Davidson FLHX Street Glide
I have a 2010 Mazda CX9, I have no leaks but 8 am losing about 2 quarts of oil between oil changes. Any insight?
Did you look for oil leaks on the engine or just going off what you don't see on the ground when the vehicle is parked. Valve cover leaks can be burned off because the leak to the exhaust manifold. Some lower leaks can be blown from the wind while driving and only produce a drop or two. The only other thing is bad rings, this would smoke out the exhaust. White with a bluish tint.
Mar 23, 2016 | Mazda Cars & Trucks
Battery fully charged, engine won't start or even turn over, gear locked in park, brake pedal is depressed.
This may help: http://www.toyotanation.com/forum/274-2nd-generation-2004-2010/199861-04-sienna-transmission-lock.html
There are multiple issues here.Won't crank? Go direct to starter.
Possible recall:http://www.toyoheadquarters.com/threads/2004-2005-2007-2009-toyota-sienna-shift-lock-solenoid-recall-d0r.206/
Nov 10, 2014 | 2004 Toyota Sienna
2010 flhx street glide bendix gear wont engage flywheel
Hi Anonymous, your battrry is severely discharged or your starter relay and or starter drive is faulty. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 27, 2013 | 2010 Harley Davidson FLHX Street Glide
2008 Mazda 9 Fuse Box DIagram
On this website, you find fuse box diagram and description
Mazda 6 (2006 - 2008)
Mazda 6 2006 2008 fuse box diagram Auto Genius
Mazda CX-9 (2007 - 2010)
Mazda CX 9 2007 2010 fuse box diagram Auto Genius
Dec 31, 2012 | 2010 Mazda CX-9
How do you install a starter ring gear on a harley davidson BDL belt drive assembly
Hi D, the beveled edge goes towards the starter bendix. Have nice day.
May 15, 2012 | Harley Davidson Motorcycles
I have a 94 mazda mx-6 that overheats. It's fine if you drive it on the highway, but it overheats driving in traffic or on the streets?
Are the fans turning on when in overheat? If not you might have a fan, relay or sender circuit problem.
Sender circuits monitor the cooling liquid temperature and then sends a signal to turn on the fans if it senses that the temp has exceeded the normal operating temp.
Jan 21, 2010 | 1995 Mazda MX-6
'05 mazda 6 will not start with new battery
Make sure connection for thick red wire going to starter is good if you had that much corrosion.
Jul 25, 2009 | 2006 Mazda 6
Starter wont engage ring gear.
eathier it needs shims or you have a bad flywheel sounds like its free spinning at times pull the starter an turn the ring gear make sure its not missing teeth if not you may need shims
Mar 08, 2009 | 2003 Mazda Mazda6
1401 Remote Start/Keyless Entry System Logo
297 people viewed this question
Top Python Vehicle Parts & Accessories Experts
ray gallant
D. E. Hev
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
