Question about Samsung SCX4828FN AllInOne Laser Printer
The printer prints, but it won't scan. The bar goes across and lights up, but won't scan or copy.
Hardware failure. It's broken, and it's too expensive to fix it. I've got the same problem, and a "solution" here:
http://www.fixya.com/support/t7084868-scanner_not_working_light_works
Posted on Dec 28, 2010
HP PSC scans with black line
If printing is ok there're two things that could cause that defect when scanning/ copying:
-. If printer model has both ADF and cam glass and problem only occurs when using the ADF then you should check the ADF glass for something obstructing light path (tipex or other type of dirt)
-. If the printer only has cam for scanning then the problem is on the sensor itself (the "bar" that moves when you scan something inside the scanner). It's not usual that dirt enters the sensor as It's pretty hermetic so I would think that the sensor is damaged and will need to be replaced.
Hope this helps.
Jul 08, 2012 | Office Equipment & Supplies
HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
Nov 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
Does not copy or scan. light flickers
everytime i try to print something it goes to this box and won't print
Jun 23, 2011 | HP DeskJet F380 All-In-One Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
My Del 962 will not scan. The light does not come on and it does nothing. What should I do?
Hi,.... I'm having the same problem as sharon_mi334. My Dell AIO 962 does not copy, fax or scan...but prints. When attempted(copy, fax or scan), the output is a scanned image or a print out that's completely black. When I looked at the "scanner light unit/ copier camera" or what-ever it's called ... the gizmo that moves across under the glass plate,... I noticed there was NO light coming out of it as it should on any other copier, etc. Sooo,... is that the problem, ie: unable to copy the image? If so, can I fix that by replacing a bulb or a particular unit? Looking for some advice and thank you for your help and time.
medflight.
Dec 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Black line
Try wiping the light bar where the page goes in with your finger.
Mar 23, 2009 | Canon PIXMA MX850 Multifunction Printer
Scan light
HI-
Yes the bub for it needs replacement. please consult a service technician that is accredited by epson, you can check one on your area by going to www.epson.com site and look for a servicer.
Hope this helps
Sep 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
HP Deskjet F2180 All in one printer
Take alook at the Scan lamp ( the light that goes across the document you are making a copy of, does it hesitate or make a sound? if you can open it and apply some WD40 on a tissue and rub the tissue on the silver bar, if it doesn't have a bar but a black belt with teeth, it may be the motor or something preventing it from running smoothly.
Jul 22, 2008 | HP Office Equipment & Supplies
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
The copy function prints a solid black page?
Do you see the light going all the way across? The printer may be having power issues. You should make sure it is plugged into the wall and not into a surge protector or a power strip.
If the light is not coming on then there is an issue with the scanner bulb and if the printer is plugged into the wall then you should call hp and see if you can have it replaced.
Jan 21, 2008 | HP Photosmart C4280 Aio Printer
Samsung SCX4828FN AllInOne Laser Printer Logo
170 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
