Question about Sony Cyber-Shot DSC-T1 Digital Camera
Lines on the screen
Lines going thru the screen. can not make out the item you want to take a picture of. Its like the resolution is messed up.
  • hfreier Jun 21, 2008
    I suffer the same problem. All object appearing in vertical lines, no focus. Old pictures on the memory stick look fine.Hence no problem with the display. Tried all menu settings, no solution. It seems the cause is electronicial. Look at the picture.
    Any other idea?
  • sushpur Jul 05, 2008
    My pictures look similarto the one posted out here, I cannot see the image in the display section, it has red hues all over it, and while blindly taking the pic, the images are blury with yellow and green boundary on them. Previous taken pics look Ok in the display window. This just happened to me in a snap, the two pics I took just a few secs ahead are just fine, then all of a sudden the display on the screen is all messed up.
I suffered the same problem with all objects appearing in vertical lines, no focus and I called Sony repair center (1-800-222-7669) here are the Hours: Mon-Fri 8:00AM-12:00AM (Midnight) / Sat-Sun 9:00AM-8:00PM EST. With the great service they had, Sony will repair my camera free of charge. Greatly appreciate for all your helps albutch.
Posted on Jun 28, 2008
This forum is the best and Sony Tech Support rocks!
Posted on Aug 31, 2008
What a great forum!! Thanks to all of you, I was able to have sony help me with the camera repair. It was very helpful to have the sample problem picture posted too.
Posted on Jul 24, 2008
Thank you rooie for providing the information, Sony is in the process of fixing my DSC-T1 for free for the problem mentioned in this thread(vertical lines when taking photo).
Great Forum!
Posted on Jul 16, 2008
Solution #2 is perfect
Posted on Jul 15, 2008
Call Sony, they will replace older cameras free of charge until September, 2008.
Posted on Jun 30, 2008
That certainly looks like the problem with the sensor. You should call your Sony Repair Centre and they will ask for your serial number. If it falls in the affected range, Sony should repair your camera free of charge.
Posted on Jun 24, 2008
Lines thru screen
sounds like the tcon is having issues. You can get replacement Tcon boards from
Mar 21, 2013 | Sanyo 42 in. LCD TV
Computer screen messed up after connecting to a Projector.
Sounds like your screen resolution has gotten changed. Plug your VGA cable in and reset it to 1024x768. Then with the laptop on remove the VGA cable. When you connect your laptop to other devices like that, make sure you are not setting the resolution to the same as the TV.
Jan 04, 2013 | Dell Inspiron 1501 Notebook
Lines of colors cover half of the screen vertical lines
Try messing around with the VGA cable to see if it may be loose or broken You could also try changing the resolution, refresh rate or any related video setting. If the lines remain the same, chances are your Video Card is about to die... But you could always try unplugging and replugging it onto your mainboard.
Mar 13, 2011 | Computers & Internet
The resolution on my monitor is messed up. Its as if every item (Whether it be shortcut or taskbar) has been enlarged by at least 2x what it was originally. I right clicked on desktop and chose...
The resolution of your system has been decreased. Follow the following steps to increase/ adjust the screen resolution.
1. Open Display Settings by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Please note that When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
Dec 28, 2010 | Gateway 4525GZ Notebook
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Red, green and blue color resolution
Hello my name is willie and i see this problem alot here at the shop. The symptons you describe is known as "convergence". OK your problem might have a simple soultion. if you can answer this question. When you acess the customer menu go into setup option.. then do you have convergence option. If you do not it will be known as the fl231 fuse. a fuse that common to blow due to bad connections. Now if you do have this option then you will have more problems with other boards. and it will have to be troubleshoot further. Does the picture also bown in at the top and bottom. when you go into convergence option(if you have it) does the cross hair move? let me know and i will see if i can help further
Sep 01, 2008 | RCA R52WH73 Projection Television
My desktop is not centered and the fonts are too big. Also my Start button and bottom toolbar have disappeared.
Sounds like your resolution has been set too low.
Firstly, i'm going to assume you have a 17" LCD monitor, and that you are running Windows XP. (what a guess!) =-]
Generally, you'd want to right-click the desktop in a blank area, select properties. This gives you the display properties. Go to the last tab across called "settings", then under "screen resolution", drag the slider up a notch and hit apply. If it looks right, leave it at that. If it's not quite right, go another notch and apply. Keep going until you have it right.
But on your 17" LCD monitor, running the DVI cable to the PC... the computer should already have detected it's maximum resolution. In this case, you can drag the slider all the way to the right and hit apply, knowing that this is the optimal resolution. Also on your Dell LCD, you should have several buttons for adjusting the screen. One of those buttons is usually a "self-adjust" or "auto detect" or "some other obvious thing" for self-adjusting the screen viewable area. It *should* do this automatically when you change resolutions, which your Dell 173FPb should do anyway. =-]
Aug 23, 2008 | Computers & Internet
I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Jan 25, 2008 | IBM E74 17" CRT Monitor
Oblong pictures
The issue here is that you have a low resolution picture and a high resolution display. Windows is "stretching" the smaller, low resolution picture so that it will fit across the larger area, thus distorting it. Right click on the desktop and select properties. Go to the Desktop tab. There should be an item there for position. Is it set to Stretch? If it is, then this is causing the problem. Set it to center, and it should appear fine. If you want to keep this from happening: 1) User higher resolution pictures. 2) Turn down the resolution on your screen (this can be done from the Settings tab of display properties).
Oct 01, 2006 | Samsung SyncMaster 940BE 19" LCD Monitor
Sony Cyber-Shot DSC-T1 Digital Camera Logo
161 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
