Question about Canon Rebel XT / EOS 350D Digital Camera
Hi... I have Canon 500D DSLR...While shotting in video mode 640+480 i got flash automatically. Is it possible to get flash while shooting in video mode.Please help
    Genius:
  • 1,177 Answers
No camera flash can operate in video mode. It would have to flash 15 or 30 times a second. It takes longer than a second for the flash circuitry to charge up each time.
You can get a separate lighting unit for video which provides constant illumination. This does not require any connection to the camera, it just provides light, and the camera will adjust exposure automatically as usual.
Posted on Nov 09, 2010
Hi i m new at slr camera , i buy canon 500d , and when i take a shot , flash light twice or more before take the shot then flash be busy then take shot with flash did it a problem or what/
Check to see if you have the flash set on "red-eye". This causes the flash to pre-flash to eliminate red-eye in your photos. It's a real pain for most photos but if you're shooting in low light, it will eliminate the red-eye.
Feb 14, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Tip
Manual Aperture Video For Canon Eos Rebel 500D T1i
Unfortunately the Canon T1i shoots video in full automatic mode. This means that if you want to change the depth of field...well, you can't. There are many angry T1i owners trying to get Canon to release a firmware update to have it perform like the T2i, but so far that has been fruitless.
So what can a budding videographer do get some artsy-looking footage with his or her T1i? The Band-Aid solution involves fooling the camera into thinking there is a manual lens attached so that the camera will relinquish control. To do this, the communication between the camera and lens has to be severed (don't worry - it doesn't involve modifying anything).
Step 1.
Put the camera into Av or Manual mode.
Step 2.
Select the desired aperture (if the aperture is "wide open" - e.g. F1.8 on the 50mm F1.8 II lens, then skip Step 3).
Step 3.
Press the depth of field preview button on the side of the camera (above the T1i or 500D logo on the curved part of the camera body).
Step 4.
With the DOF preview button still depressed, push the button as if to remove the lens, and turn it very slightly until "F00" shows up on the back display. You may now release the buttons.
Step 5.
Switch the camera to video mode. There will be a warning message, but just do as it says and shoot anyway.
You're now ready shoot some nice shallow DOF shots. Use the manual focus ring on your lens to shift the shallow depth of field around in your shot. Please note that since the camera is no longer communicating with the lens, autofocus will not be available to you. Put the lens in manual mode on the barrel to be safe - many lenses do NOT have manual override and forcing the focus ring while in AF mode can damage the lens.
Good luck and happy film-making!
on Jul 24, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
I have new Canon 500d but i can't work out the LCD screen to display my live view to shoot. The screen displays only the Menu or the Shooting Settings Display. i have the same problems with Rina, Thanks...
I wish you know that you need to press LIVEVIEW button marked red Dot to enter live view mode.
Further more it will work in P,T,A,M modes and video camera modes only.Still it does not show live view the camera has a fault.
If this has solved it don't forget to rate me.
Oct 17, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon 500d Screen won't display object to be shot
First of all, the live view mode will work only in creative zones, that is from mode P. P, Tv, Av, M modes. Put the camera into one of these modes and push the Set button that is located behind the camera, amidst the four direction buttons, and you're live! Also note that to autofocus here, you should use the zoom minus button, a button with a star beside it.
Jul 10, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Canon 5d
Make sure you have your flash & timing set where it is supposed to be, usually between 120 & 180. This is the shutter timing and flash duration. It is the syncronizing speed setting. If possible, turn off the automatic review, this slows things up. Also, if possible, use a power cord for the flash instead of batteries. Not all have this feature but, the flash is ready for the next shot in about 1 second.
Jan 27, 2009 | Canon EOS-5D Digital Camera
Digital Camera
this is a problem called shutter lag. This is something common with normal point and shoot camera such as yours. Consider investing in a DSLR, A DSLR excels in this area.
Jan 20, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
