Question about Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX
Media test failure
I have created the xp boot up disk but now i'm having a problem that the cd is not being recognized. it states" media tes failure.. check cable"
Help
Due to current fluctuations my smps and ups was burnt, so i called the technician he replaced the ups,smps and motherboard ,and then my computer turned on when it was booting it showed a message like "media test failure check cables" and then i can see my desktop with all icons.but i dont see any sound symbol on the task bar the place where we can time.when i open the control panel>sound and speech options it shows like no audio device.
when i try to play any song through windows media player it shows a message like sound card or sound controller is not installed in the computer install the sound card.and my computer has internal sound card. what should i do now, shall i purchase new sound card so that i can connect it to pci
Posted on Oct 01, 2008
When I turn on my laptop acer aspire 5552 the screen is black it says media test failure, check cable, cable is ok, it also says existing broad com PXE ROM, no bootable device -- insert disc & PRESS...
#1. Verify there are no disks in the floppy or CD drive.
#2. Get into the BIOS and set everything to default.
#3. Have a friend create a boot disk for you or, if you have a program that is self booting, use that to get in.(i.e. Windows)
Jun 19, 2014 | Computers & Internet
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
My computer won't boot up with windows xp service pack 3
This is a strong indicator the hard drive has failed, have it tested before replacement.
Jul 10, 2012 | Toshiba Tecra Computers & Internet
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Jul 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
Argon PXE Boot Agent v2.01 2002 - PXE - E61
* floppy-disk
* disk-drive
* CD-ROM
* USB memory-stick
* over a network, via PXE (Pre eXecution Environment)
If you have a network-cable connected to the Ethernet port on the computer, with the other end connected to a "boot-server", then the Operating System can be loaded over this network-connection.
But, if you get "media test failure" and "check cable", then the network-cable for PXE is either non-working or not-present.
Any disk-drive that shows "ZERO" blocks is very probably a DEAD disk-drive. Replace it.
Jun 03, 2009 | Compaq Presario 2100 Series: 1170B01-90...
PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
WINDOWS XP MEDIA CENTER
try going into the bios and changeing the boot device to hard drive. More iformation is needed though to help you ie os version, what you done just before this problem had arisen , brand name of your computer. let me know im sure i can assist you and try not to get frustrated these things happen more often than you know.
Oct 27, 2008 | Microsoft Windows XP Media Center Edition...
Media Test Failure, Check Cable.....
This is an Invalid / Non System Disk error.In your Bios settings change the "First boot device" option to your hard disk.If you have only one hard disk set it to "HDD 0"
Other causes of the problem are:
  1. Floppy or CD that is not bootable is currently in the computer.
  2. Hard disk's power or data cable is not connected properly(loose contact)
Oct 12, 2007 | Acer Aspire L310 (ASL310UD631A) PC...
Intel D915GAG Socket 775 Motherboard - 915G Chipset - Onboard Audio, Video, Lan - MicroATX Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
