Question about Intel Shiva LanRover D56 Modem
RAS issue Hello, I'm trying to fix an old shiva installation that was working but don't work anymore since i changed the IP and changed it back to the old one (rollback cause our change didn't work as expected). Since this time, it seems the remote application trying to connect to the company network can authenticate through the Shiva Access Manager (the log files seem ok) but can't join the server where it should work. I can't find any error in Shiva Access Manager or in the console but the application is disconnected after 30s and send back a network error. Have you some idea about this ?
2 Suggested Answers
SOURCE: lost lanrover d56 password
The easiest way is to do a pin reset. If you look at the front of the box you'll see a small whole which has a button in there. You need to press and hold down the button for a period of time, I can't remember exactly how long but I think its about 15 seconds. This should reset the box.
I think theres another method which is a Shiva backdoor method. Try logging in with the username and password ROOT. Try this before you try the other method because if you can get in it will save you having to reconfig the whole box.
Posted on Dec 11, 2008
Cant connect to wlan since 4 days
There may be a radio issue with the units.
Contact Lexicon Technologies for help - www.LexiconTech.com - 1.800.678.1744 - repair@LexiconTech.com
Aug 16, 2012 | Zebra Symbol Technologies MC909X-G Series...
Expant Shield does not connect anymore. One day it worked fine and since about a week it does not connect anymore. No changes to location, computer, internet connection, etc. Possible that my ISP (I live...
That is a typical problem/issue. What happens is the ip block gets blacklisted and no longer works. All you need to do is wait a few days and it should work again. I think the longest I've seen it down lately is about 4 days or so. Hotspot is pretty proactive on fixing the connections so it usually is much faster. There are a few things you can try such as disconnecting, wait a minute and then reconnect to get a different ip. If the ip is out of the blacklisted range you should be able to watch the BBC/IT4 etc again right away. If not then about all you can do is wait and keep trying to connect. The disconnects I've seen recently are very short compared to when they first started. Those lasted weeks sometimes.
Oct 15, 2011 | AnchorFree Expat Shield
Enable LAT protocol on Shiva Atom?
Since the only thing that changed was the Shiva Atom, I'm guessing that the license error is coming from the terminal server itself rather than the VAX, corrrect? My only suggestion would be to replace the ethernet chip on the new server with the one from the old server. Perhaps the license is tied to that address. It should be a small 8 pin IC in a socket. At the time of these units being built, the Ethernet ID chips were usually installed in sockets.
Hope this helps,
Dan
Apr 30, 2009 | Intel ShivaPort Atom (SATOM16TX) Terminal...
I had bluetooth on my labtop and now it's not their anymore
u should install bluetooth software again.....
i m sure it will start to work again..
best of luck..
shiva
May 21, 2008 | Computers & Internet
How can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
May 15, 2008 | Microsoft Windows Server Standard 2003 for...
Lost lanrover d56 password
Do you have the Shiva Security Manager at Start > Programs > VPN link ? If not I can help you through it.
Aug 07, 2007 | Intel Shiva LanRover D56 Modem
Intel Shiva LanRover D56 Modem Logo
48 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
