Question about Acer X173WB Monitor
Acer x173wb is not full screen. the buttons at the bottom are not fixing it
Exit full screen
It depends on what application is causing the full screen mode. Try one of the following
- hit Esc key
- Hold Alt button, while pressing Tab - this will bring up all applications that are running - you can select the desktop.
- press Alt and F3 buttons together - this will close the application that is running in full screen.
May 05, 2014 | Acer Computers & Internet
I need to do a full system restore to factory settings, but i do not have a recovery disc for this laptop. I have tried the F8 button and the F10 button but dont seem to be getting the right option to...
To do a full system 'recovery' search under 'recovery' in the help screens and click on the recovery console in windows, if you can get that far.
'Restore' goes back to a particular time in the past where the system was working properly, but doesn't necessarily take it back to factory settings. You can search under that option as well if you can get into windows.
Good luck on this repair.
Jan 30, 2011 | Acer Aspire 5315 Notebook
In My Acer LCD X173W,Appears Coloured lines on the right side.
disconnect all the cables from the monitor except the power you wouls see a test screen .
if you still see the lines its the monitor is bad better buy a new one as repairing is expensive .
Apr 17, 2010 | Acer X173WB Monitor
19" monitor problem
Try 1440x900.
Some LCDs don't like going off their supported resolutions.
Dec 09, 2009 | Acer X173WB Monitor
The picture shakes
install the monitor driver..you can find it in manufacturer's support link and also run the video and monitor diagnostic software to calibrate the colors...acer might have the software
Mar 13, 2009 | Acer X173WB Monitor
Bottom of screen cut off
This is a limitation because of the screen size of the Aspire One. Unfortunately, no fix for that...Sorry
Mar 06, 2009 | Acer Aspire One Netbook 8.9" Notebook
No signal
Start the pc in SAVE MODE to do that kep  F8 at the startup and than change size of the screen.
Jan 18, 2009 | Acer X173WB Monitor
Little buttons on bottom of screen
How do i set the time can not see it on my screen
Oct 06, 2008 | Acer AL1917W LCD Monitor
Acer top and bottom of screen is blank
on the monitor press the menu button in that adjust the horizontal and vertical size correctly ... you will having the option to adjust in the menu button ...
or you may be using some low resolution check the display properties set your resolution to 1024 x 768 ...
this will fix your problem ...
thank you
bye
any doubts you can reply me
i am always here to assist you
rate my solution
Aug 12, 2008 | Acer Computers & Internet
Acer X173WB Monitor Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
