Question about IBM Infoprint 1552 Laser Printer
Buona sera. ho appena fatto il kit di manutenzione alla mia stampante infoprint 1552 ma permane il messaggio a display "80 manutenzione programmata. quale è la procedura per resettare il contatore manutenzione? grazie e buon lavoro
5 Suggested Answers
SOURCE: resetting IBM infoprint 1552 maintenance counter
Go Here: it's a PDF file which explains how to reset the printer's maintenance count.
http://www.marketpoint.com/files/pdfs/mk_ibm_1532.pdf
Posted on May 15, 2008
pineworks
  • 4041 Answers
SOURCE: problema di bloccaggio HP C5180, errore inchiostro 0xc18a0107
Hi no harm in trying I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
  • 18 Answers
SOURCE: My IBM Infoprint 1552 is leaving gray spikes at
Check your toner cartridge (most print quality problems are toner cartridge problems) if that is not the problem (and it probably is) then check the fuser for toner buildup matching the defect you have. There is also a small possibility of the laser being deflected and causing this (unlikely) but clean the small mirror above the toner cartridge (it is small in height and as long as the machine is wide and up in a cavity)
Posted on Apr 05, 2010
ginko
  • 19396 Answers
SOURCE: Ho cambiato le cartucce alla mia stampante mp
Ciao.
Assicurati d'aver rimosso il nastro adesivo dalle cartucce.
Controlla i contatti dentro l'alloggiamento delle cartuccie. Eventuamente pulisci i contatti con alcol e cotone idrofilo.
Fai un test usando altre cartucce. Cartucce difettose sono un problema abbastanza comune.
Se questo non risolve il problema, e la stampane non riconosce NESSUNA cartuccia, neanche le originali. Allora qualcuno dei contatti dietro la testina e' probabilmente rotto.
Questo tipo di guasto non e' comune, di solito sono cartucce difettose, sensore nell'alloggiamento sporco, o problemi software.
Controlla anche il software stampante, reinstallalo rimuovendo prima la stampante dal pannello di controllo. Assicurati d'aver seguito la procedura di rimpiazzo usando il software Canon. Il semplice scambio di cartucce puo dare adito a problemi.
Posted on Jul 01, 2010
Buon giorno, la mia macchina Saeco Magic de Luxe e' appena stata in assistenza ed hanno dovuto cambiare la scheda. ora non riesco piuu' a far girare acqua nel circuito. accendo la macchina ma mi...
Anch'io ho lo stesso identico problema, l'ho smontata, ho dato un'occhiata e credo di aver capito che il problema sia la turbina (rotta) ma non ne sono sicuro..!! Ho dato un'occhiata in rete e una turbina costa circa 12 euro... credo convenga fare questo tentativo..!! Ciao Adriano
May 10, 2011 | Saeco Magic De Luxe Espresso Machine
SmartBase MP360 appena avviata per qualche secondo fa rumore di pettine contro acciaio e non funziona
Questo rumore clunking / rettifica di solito ? un ingranaggio inceppato o una barra di controllo provocando qualcosa da cedere il passo (di solito l'elastico con i denti su di essa dietro la testa). Ho risolto i problemi simili su HP e Epson e ogni volta che ha bisogno di una striscia gi? e un attento esame delle lavorazioni. con Epsons di solito era un ingranaggio che aveva saltato un dente e poi la tempistica era fuori causando un inceppamento. Con polipi iperplastici, di solito un frammento di carta nelle opere o inchiostro schizzato su uno dei tanti sensori ottici, facendo accadere le cose nell'ordine sbagliato. Il mio MP360 inceppata con i capi in sosta (ma senza clunking). Ci? ? stato causato da inchiostro secco mescolato con polvere di rendere il meccanismo di pulizia pigro e (in qualche modo) jamming la testa. Ho preso le coperte per spegnere la stampante (un lavoro lento) e pulito tutto, ri-ingrassate. problema scomparso. Attualmente ho le teste ammollo in una miscela di alcool, detersivo liquido e acqua per sbloccare le teste di nuovo.
Jan 19, 2011 | Canon Office Equipment & Supplies
C max 1600tdci diesel 110 cv anno 2004 errore u0101
certamente il codice indica che non c'? comunicazione tra il cambio automatico e il traction control module o centrallina
controllare il cablaggio e connettori
May 24, 2017 | 2006 Mazda 3
Ho cambiato le cartucce alla mia stampante mp 630,mi riconosce solo il giallo e il magenta,ho fatto una 20 di volte la pulizia ma niente
Ciao.
Jul 01, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannot access port 9339.
It's probably that Windows Firewall (or Mac firewall if you're a mac person) is blocking the port because it doesn't recognize the source. You'll have to go to your firewall settings and open/unblock port 9339.
Jul 09, 2009 | Facebook Social Network
Devo resettare la stampante brother mfc 260
Ho lo stesso problema con il nero della mia MFC 235 C. E' uguale alla MFC 260 chi può aiutarmi?
Jul 07, 2009 | Brother MFC-260C All-In-One InkJet Printer
Ho perso manuale di uso e manutenzione posso averlo on line ?
Clicca il link qui sotto per scaricare il manuale in Italiano:
Download italiano Libretto d'uso
Qui c'e anche la pagina di supporto Miele.
Non dimenticarti di votare adeguatamante la mia risposta, se questo ha risolto il problema vota blu, se ha aiutato blu, se non e' di aiuto giallo, il rosso e' per chi ti insulta.
Io direi che se cercavi il manuale qui il blu ci sta'.
Ciao, e in bocca al lupo con l'asciugatrice.
Jan 05, 2009 | Miele Novotronic T230C Electric Dryer
Problemi con explorist 500
Ciao, mandami una email a casa1111@libero.it altrimenti tramite questa via ci mettiamo fino all'anno prossimo. hai messo una basemap europea sulla SD card? nella directory "Backgroud maps"? se hai fatto così avrebbe dovuto sentirtela. Se in ogni caso metti la basemap europea nella directory USBTRANS della SD card dovrebbe caricartela nella memoria interna del GPS (dopo il caricamento non è più presente nella SD card, per cui se devi ripetere l'operazione devi rimettercela).
Ciao
Alberto
Oct 04, 2008 | Magellan eXplorist 500 GPS Receiver
Errore F6
Errore F6 (F06) significa problemi con il motore, o con gli ingranaggi di trasmissione del motore.
La scheda di controllo della tua lavatrice rileva che il motore non sta girando alla velocita' richiesta o e' guasto.
Di solito , quando questo si verifica il tecnico controlla il motore, la trasmissione (motor coupling), l'unita di controllo del motore MCU (motor control unit), e sostituisce la parte difettosa.
Controlla questo link per avere piu dettagli su come risolvere il problema.
Non dimenticarti di votare la soluzione, possibilmente con quattro rombi azzurri.
Grazie.
Sep 03, 2008 | Whirlpool AWT5108 Top Load Washer
Apri la mia dvd rec jvc drmh30s, solo LOADING....co fare RESET?
Vedo solo adesso il tuo messaggio, era stato dimenticato nella coda.
Sono contento che sia riuscito a riparare il tuo DVD.
Se hai ancora bisogno d'aiuto chiedi pure.
E se vuoi chiedere in inglese (e' piu facile che ti rispondano) usa il traduttore di google.
Buona fortuna.
Nov 21, 2007 | JVC DR-MH30S DVD Recorder
IBM Infoprint 1552 Laser Printer Logo
87 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
