Question about Troy-Bilt Heavy Machinery
Briggs & Stratton 650 (Model 120000) lawnmower engine on a Troy-Bilt CSV060 lawn vacuum/chipper/shredder. Was stored for several months with no oil/gas. Recently got it out and filled oil/gas. Would not start at first, though after a couple of days of trying it now starts with blue smoke, runs clean for 30 seconds, then stalls out. I have what looks like engine oil dripping from out of the air filter/carburetor assembly.
  • Winfried Schoepf Jul 10, 2017
    you are clearly burning oil. did you overfill? or tilt the unit so that engine oil went into the carb through the breather? now the carb may be soiled/partly clogged, you need to clean it. esp. the idler air part may be at fault. sometimes it is possible to run it at high rev until the fuel has washed out the oil, but better clean the carb and replace the air filter.
    Top Expert:
  • Troy-Bilt Master
  • 83,843 Answers
Check the crankcase oil level
Posted on Jul 10, 2017
  • 20 Answers
You are clearly burning oil. did you overfill? or tilt the unit so that engine oil went into the carb through the breather? now the carb may be soiled/partly clogged, you need to clean it. esp. the idler air part may be at fault. sometimes it is possible to run it at high rev until the fuel has washed out the oil, but better clean the carb and replace the air filter.
3 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: Describe your Troy Troy-Bilt® Briggs and
there should be a set screw in the impeller holding it on the shaft.take the set screw out.then the impeller should come off.if it doesn't come off easily you need to heat the hub that the set screw was in.this expands the metal so that the impeller will come off..........there is no easy way to do this job........hope this helps,let me know..................
Posted on Jun 26, 2009
rwvanlue
  • 486 Answers
SOURCE: Misplaced operation manual for Troy-Bilt Briggs
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Posted on Nov 08, 2009
I have a Troy-Bilt 24A-06MM066 CSV060 shredder/chipper combo that won't start
Your carb is gunky up from bad gas most likely.
Anytime an engine will run for a bit after putting gas into the carb, you are pretty well assured that it's the carb.
Remove and clean the carb paying special attention that all the little orifices are open by spraying carb cleaner into them.
Aug 04, 2014 | Troy-Bilt 24A-06MM066 - CSV060 24" 173cc...
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Oo.comI need a motor diagram for Briggs and Stratton 5HP shredder chipper
Get the model and type number off the engine and you can go to a website like partstree.com or others and with the brand and the model and type number you can get diagrams of the engine.
I hope this is helpful for you.
Aug 13, 2011 | Troy-Bilt® Briggs and Stratton Chipper
Location for adding oil?
Most small engines have a cap where you check your oil level. This is also the access for putting in oil.
Here is a link to the Troy-Bilt site for chiper shredders. I don't know what model you have but you can select your model and obtain a users manual.
http://www.troybilt.com/webapp/wcs/stores/servlet/category2_10001_14102_54996_54995_54995_-1#
I hope this helps you. Good luck!
Jul 08, 2010 | Troy-Bilt® Briggs and Stratton Chipper
I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
Nov 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Troy-Bilt Chipper Shredder won't start
It takes good gas, good spark, and good air for a gasoline engine to run well. The next thing I would do is put a new air filter in it.
Apr 23, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Heavy Machinery Logo
1,360 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
quennie732
Mike
lnbn1975
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
