Question about Acer Computers & Internet
Cannot locate Wi Fi on my laptop. How can I "reinstall" the Wi Fi ?
  • 44 Answers
SOURCE: Wi-Fi Download problems with Acer 5920
http://www.notebookera.com/notebook-drivers/s_138_1.shtml
Posted on Sep 26, 2008
Silverblade
  • 173 Answers
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
Posted on Nov 05, 2008
citirulez
  • 44 Answers
SOURCE: Wi-Fi not connecting on Toshiba Satellite A15-S157 PC Notebook
you tried giving it a static IP address rather than using automatic settings (i.e. DHCP). Sure enough, this cured the problem, connected fine. I looked in the dhcp server logs and while it was not complaining that the IP address pool was all used, it did seem that all the IP addresses available were being used. I increased the number of IP addresses available to be allocated by the dhcp server and problem solved. The big mystery to me is why Windows XP would report this as a problem with a weak signal? Isn't the access to the dhcp server and the allocation of the IP address at a layer above the wireless connection? Anyway, it's useful to be warned that the wireless diagnostics are misleading.
Danseo246
  • 35 Answers
SOURCE: Want Instant wi fi when turning on my laptop
Hp comes with a wi-fi utility and I dont find it very useful, so first, you might want to uninstall the software from add or remove programs and then use windows to manage your wi-fi.
Once you connect to a wireless network from 'network connections', it will automatically be set to default and should connect at the computer startup.
If it does not connect automatically.go to 'change order of prefered networks' and put your prefered network on top and set to automatically.
Posted on Dec 29, 2008
  • 47 Answers
SOURCE: my problem laptop not working wi fi connection connect phone
ok.
its knows that vista isfull of bags and corraps.
the fing is a computer with vista req a heavy vid card such as 9xxx (dont go on 8800 it is waste of money) and you need 2-4 gb ram for your computer to work perfect and so the best fing you can do try to download windows7 beta it is like windows vista but acts like xp wich is the best so look for a good downloadand goodluck.
Posted on Aug 15, 2009
Tip
How to manually enable Wi-Fi on an iPod Touch
<p>IPod touch not only offers a music library on the road. It also has Internet capabilities. The iPod touch can connect to wireless internet connection available and browse the web using the Safari browser included on the device. Typically, Wi-Fi capabilities automatically. But if your iPod touch wi-fi is off, or if you activate it, you can do it using the Settings window. <br /> <p><br /> <p>1. Touch the "Settings" icon on the main screen of the iPod touch. <br /> <p><br /> <p>2. Touch the option marked "Wi-Fi." <br /> <p><br /> <p>3. Touch the "On" next to the setting marked "Wi-Fi." <br /> <p><br /> <p>4. Tap a wireless network list to connect. <br />
on Aug 05, 2011 | Computers & Internet
Tip
How can I get a Wi-Fi for iPod touch?
<p>Make a network connection Wi-Fi in the Settings menu of your iPod touch. Touch can connect to any open wireless network, or to closed networks as the password. If you're within signal range of your wireless network, tap the Settings icon for a network connection Wi-Fi <br /> <p><br /> <p>1. Tap "Wi-Fi" in the Settings menu and make sure the slider Wi-Fi is set to "On." <br /> <p><br /> <p>2. Waiting for a pop-up window appears with a list of available networks. Tap the name of the network you want to participate. <br /> <p><br /> <p>3. Enter the password for the network. If no password is required, the iPod will not ask for one. <br /> <p><br /> <p>4. Select "Cancel" if you have a closed network that is not in the list to close. Tap "Other" closed and the network name and password type of security. Use this option if you have access to a Wi-Fi network is closed not featured in "available networks." <br /> <p><br /> <p>5. Check the left corner of the screen. When connected to Wi-Fi indicator lights. The iPod touch will automatically detect and connect to that network when the signal range. <br />
Dell adamo laptop wireless stopped working. Is there a switch? It works with my router when I plug the etherenet cable in
There is no physical switch to turn on/off the wi-fi card. Check to seeif your wireless card is displayed under "Network Adapters" in "DeviceManager". You can access the "Device Manager" by going to the'Control Panel", "Administrative Tools", "ComputerManagement" and select "Device Manager" located in the left sidecolumn. If it is detected and there are no alerts or errors, try uninstallingthe wi-fi card, reboot the laptop and reinstall the drivers.
Feb 20, 2011 | Dell Adamo Laptop
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
Tip
The "Bubble Breaker" Get on the iPod Touch
<p>The iPod Touch, a portable media device, Apple has a 3.5 inch screen touch screen, making it suitable to play games like Bubble Breaker. Bubble Breaker is a game you play by choosing the same color bubbles and playing to make them explode, earning a higher score more bubbles you burst at once. The iPod Touch connects to the Internet via Wi-Fi, so you can easily access the App Store to download Bubble Breaker on the device. <br /> <p><br /> <p>1. Press the "Home" button, located below the iPod Touch. <br /> <p><br /> <p>2. Tap Settings, then "Wi-Fi and tap the" Wi-Fi "option set to" On. "Touch the" Ask to Join Networks "to" On. "Go to a place where you are within range of a hotspot Wi-Fi as a home or a corporate computer network or a public library. The iPod Touch will automatically try and connect to WiFi networks <br /> <p><br /> <p>3. Enter a password for the Wi-Fi network when prompted. <br /> <p><br /> <p>4. Press the "Home" to return home from the device. <br /> <p><br /> <p>5. Touch the "App Store" icon. Tap "Find" and type "Bubble Breaker", and then tap again on "Search". Tap "Bubble Breaker" from the search results. <br /> <p><br /> <p>6. Tap the price, next to the icon located Bubble Breaker, then "Install". Enter your Apple ID at the prompt. Bubble breaker game downloaded and installed on the home page screen iPod Touch. <br /> <p><br /> <p>7. Touch the Bubble Breaker game to start playing. <br />
on Jul 21, 2011 | Computers & Internet
Tip
How to turn on Wi-Fi on my locked iPod
<p>The ability to connect to the Internet via Wi-Fi is an important feature of the iPod touch. With Wi-Fi, you can surf the Internet, check your e-mail and online games. But first make sure that the WiFi connection If your iPod is locked, you must unlock before you can change the connection settings. <br /> <p><br /> <p>1. Press the "Power" button in the upper right or the "Home" button on the iPod screen to activate the screen. <br /> <p><br /> <p>2. Slide the locking bar from left to right to unlock the device. If the password-protected your iPod, type the password. <br /> <p><br /> <p>3. Click the "Settings" app icon, and then click on "Wi-Fi in the Settings menu. <br /> <p><br /> <p>4. Turn on the Wi-Fi pressing the "On / Off" button in the upper right corner of the screen, then see the available networks. Click a network to connect. If the network is password protected, enter the correct password and click "Join" to activate the Wi-Fi on your device. <br />
Is there a wi-fi swtich on thinkpad r52?
IBM load there own set of software on there notebooks which take care of networking lan and wi-fi, I have found if try to use the windows native wireless checker it does not pick the networks up. Try using the IBM program either in the taskbar near the clock or in the start menu.
Also in Device Manager does the wi-fi device show up.
There also may be a light that indicates wi-fi is on on at the front or or above the keyboard if its off let me know.
Other possibility is to uninstall the driver for the wireless device restart and let it reinstall automatically.
Mar 18, 2009 | IBM ThinkPad R52 Notebook
You can try reinstall the wifi driver or update to lastest edition. Check here http://support.acer-euro.com/drivers/notebook/as_5920.html
Sep 23, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Tip
How can I permanently delete a Wi-Fi from iPod?
<p>Include network interface, the iPod Touch is equipped with a wireless adapter that allows hardware to join Wi-Fi networks by default, an iPod Touch love all Wi-Fi was never confirmed, this feature saves users the reenter the work of key network authentication and other parameters. However, in some cases, a user can have a Wi-Fi network to remove the memory of the iPod touch - for example, when the network configuration has changed. You can also prevent applications such as Safari Internet access. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that moment, the iPod Touch lost all memory you have connected to that network - past and configuration parameters. <br />
Computers & Internet Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
