Question about Sanyo Office Equipment & Supplies
The projector powers up but turns off after 1-2 minutes
  • eric_cumming
    eric_cumming Nov 02, 2012
    The Sanyo turns on (with the green light showing), then after a few seconds the warning light turns solid red.
    Brigadier General:
  • 8,909 Answers
There ar a few reasons that will occur. The main two are,
If there is no signal and if it is overheating.
If there is no signal. that is an easy fix and so is the overheating.
Consult your instruction manual and remove the filters, clean the air intakes and filters and refit the filters.
Hope that helps.
Posted on Nov 09, 2010
  • 1 more comment
  • ste_moore Mar 04, 2011
    Just found the two exhaust fans on the left side were sucking in. Had been installed the wrong way round from new.
  • specialistel Mar 04, 2011
    Even the manufacturers get it wrong in assembly some times.
    Pleased to help.
  • Robert Wilson Oct 02, 2013
    I have the same problem, took the filters and and cleaned them...still turns on and then turns off after a few seconds. Changed the bulb. If I unplug it and let it sit for a few hours it will turn on, but if you turn it off and then try to turn it on, it will turn on but then the red light starts blinking again.
We have an Acer P3250 projector that keeps prompting for a password upon start-up. However, when we enter the security password provided with the unit, it says it is "invalid".
Found an earlier suggestion on this site if you don't have the provided password and also already tried 1234.
1. Turn on the projector 2. Press "Power > Left > Left > MENU" (Opens the system menu)
3. Choose "RD Menu"
4. Choose " EEPROM Restore" (the projector turn off and the power lamp blink red for about 1 minut. Then it stops)
5. Turn on the projector again and it should work again
Acer P3250 will not acccept password
Mar 27, 2015 | Acer P3250 DLP Projector
Acer P3150 lcd projector password-locked which was not earlier set, security card lost. Tried to input default numbers such as 1234 and 000000 but not working. Is there any solution to solve this problem?...
I found a solution that worked for me:
3. Choose "RD Menu"
5. Turn on the projector again and it should word again
Jun 23, 2011 | Acer P3250 DLP Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
I have an HP VP6111 projector. It hasn't been used for about 6mths and now I try to power it on and the Blue light around the on/off button will light up for about 3 seconds and then turn off. I've...
Please do not unplug the power cord before POWER is shut down or during the two-minute cooling process.
If the projector is not properly shut down, to protect the lamp, the system will detect this and cool the lamp for two minutes automatically before turning on again.
Check that you are doing this.
I suspect that this is not your problem though.
It seems that the blue light doesn't flash very long. do any other lights come on during the startup process.
Mar 25, 2011 | HP VP6111 Multimedia Projector
Our projector has said replace lamp for approx. 1 year. We did and it still saying to place lamp. Also it stops projecting after about 5 minutes and then 10 minutes later we are able to use it again for...
You need to reset the LAMP RUNTIME counter
1. Press the MENU button to display the menu screen
2. Press the UP and DOWN arrow buttons to select the "OPTION" menu
3. Press the ENTER button and then press the UP and DOWN button to select the LAMP RUNTIME
4. Press and hold the ENTER button for approximately 3 seconds
5. The LAMP RUNTIME screen will be displayed.
(Note: press any button other than the Power button to cancel the LAMP RUNTIME screen)
6. Press the POWER button to turn off the power
7. After the POWER button on the projector illuminates red you restart the projector
and check the LAMP RUNTIME counter it should be "0"
Nov 24, 2010 | Panasonic PT L735U Multimedia Projector
My Acer P3150 projector is locked.Am not sure how this happened as I didn't put in any password. I need to put in a password. I don't have the security card with the "Universal Password". I need the...
3. Choose "RD Menu"
Sep 02, 2010 | Acer P3250 DLP Projector
Acer P3250 will not acccept password...
3. Choose "RD Menu"
Sep 15, 2009 | Acer Office Equipment & Supplies
Problems with keeping the projector on!!
if it is blanking orange:1- if any objects are blocking the air inlet or outlet grille remove them.2- do not expose the air outlet to hot air emitted from heating appliance.3-check whether the filter is clogged with dirt-clean the filter if clogged.
if it is blanking green:-after status indicator stop blanking press power.if you unplug power cord while the fan is rotating the lamp may be not turn on for one minute next time you plug the cord.
press power button several times.
Dec 08, 2007 | Mitsubishi HD4000U Multimedia Projector
2,643 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
