Good day,
Assuming the temperature in the freezer is normal ( 0 to 4 degrees) then it is usually the water valve located on the back, bottom rear of the machine starting to fail.
As well, The water line and it's fittings could have become corroded and need cleaned or replaced.
Unlike washing machines, which wait until the the normal level is reached, ice maker fill is determined strictly by time. Normally about 7 seconds. If the supply is weak, as described above you will have the issue you described.
