Question about Cameras
How to use my camera
I need help figuring out how to take pictures and get them on my computer. i can not get the right setting i guess. what setting does the camera have to be on to save the pictures?? if you can help me i would appreciate it.
    Novelist:
  • 97 Answers
No matter what setting the camera is on, it should be saving your pictures. It's possible that your card is full or your internal memory is full. It's also possible that your memory card is "locked" meaning that the little switch on the side of your memory is card is switched to the locked setting. If you could tell me what kind of camera you have, I could give you more detailed instructions.
Posted on Jun 16, 2008
Trouble dowloading pictures
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Aug 05, 2012 | Canon PowerShot SX30 IS Digital Camera
Samsung L100. How do I take pictures off camera itself? Before I got card, I took some photos and I cannot figure out how to take those picture from camera.
Hello there, Just plug the camera to your computer's usb port and turn it on and set it to review mode. Once the computer detected it as a new usb device, RIGHT click on your Windows start button and choose Explore or open Windows Explorer. Then click on My Computer or Computer from the left pane. Look for the drive letter associated to that camera then click on it to show the contents of the camera on the right. Browse thru the folders until you find the pictures. Once u found them, just copy and paste to your local drive. If you need furtherr assistance, please let me know. Thank you for using FixYa.
Jun 24, 2011 | Samsung L100 Digital Camera
I can't figure out how to use the large screen to set my picture to take it I can only use the small viewfinder
Not knowing the make or model of the camera you have I can only guess that there is a switch possibly lower right of the small viewfinder with the letters LCD/EVF. This would be a slider type I'm going to presume but may be a button. This switch will toggle between viewfinder and LCD
Dec 31, 2010 | Cameras
EOS Rebal XS stuck on self-timer
1)Press the left arrow key (which is located to the left of 'SET' button at the back of camera). It has clock pictogramm near it.
2)Use left/right arrow key to select square pictogramm to set drive mode to single shooting.
3)Press SET button to confirm your choice.
May 28, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Pictures are fine in camera and on computer but blurry when memory card is installed in television
I'm guessing your tv screen is much bigger than the computer screen. You're stretching the pixels past their limit and that's why the picture is blurry. How many megapixels is your camera capable of shooting and do you have your camera set to take the maximum at the finest quality setting?
Jan 11, 2010 | Cameras
Date and time removed
it better to take the master batterys in the cam
Mar 27, 2009 | Polaroid T830 Digital Camera
The flash won't turn on
what kind of flash ? SB800 ?Sb600 ?
or are you using compact..if you're using compact,I guess you'll be needing Manual mode and tweek something on the setting menu.
Jan 31, 2009 | Kodak EasyShare C763 Digital Camera
I need to delete pictures off of my polaroid digital a300 camera.
Solution: Greetings happyone1,
To delete pictures off your camera, please do the following:
1) Set the camera to playback mode
2) Press the M button
3) Use your up and down buttons to chose the trashcan icon (erase)
4) Press the right directional button. You will be given a choice of Erase This or Erase All.
5) Press the up or down button to select the desired setting.
6) Press the right directional button. You will be given a choice of Erase This- No or Yes
7) Press the up or down button to select the desire setting.
8) Press the OK button.
You can also find this information at the following link:
http://www.polaroid.com/service/userguides/digital/cameras/a300-310_ug_en.pdf
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Apr 30, 2008 | Fuji FinePix A500 Digital Camera
San Disk Memory Stick Pro Duo 2.0 GB
Is its reading from camera are you watching your pictures from camera if yes what the error is showing when you are opening and it which company memory stick and what operating system it support give me the memory stick details
Mar 15, 2008 | Gateway 507GR PC Desktop
Blurry pictures
You're both right. The pictures are blurry because the shutter speed is too slow, but it's too slow because there isn't enough light for it to be faster. Try this: Set the ISO to 800 Set the camera at shutter priority mode, and enter 1/160 for wide angle to mid-zoom, and 1/400 for full zoom. If the pictures come out too dark ( and you're too far to use the flash ), you can always brighten them on the computer. But if they're blurry, you can't really fix that.
Sep 11, 2005 | Olympus Camedia C-700 Ultra Zoom Digital...
Cameras Logo
105 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
