Question about Startrac Fitness Products Star Trac Pro S Treadmill
Display showing "check motor system" and "elev
Kodak I1X09 fault code
I1X09 One Line Description: INSERTER SUPPLY 3 stalled when it was moving down Error Type: Soft Shutdown Error Description: If the ELEVATOR STEPPER MOTOR uses more than 130% of the maximum number of steps to move the PLATFORM of INSERTER SUPPLY 3 down to the expected position, the INSERTER SUPPLY CONTROL BOARD determines that the PLATFORM has stalled. An I1X09 error code is recorded in the error table and you must either use another INSERTER SUPPLY or press OK on the OCI to clear it. Theory guide: I1INSER1 Possible Causes:
1 The input to LOGIC and CONTROL from the DOWN LIMIT SWITCH is not correct. 2 The input to LOGIC and CONTROL from the PAPER FED SENSOR is not correct. 3 Mechanical binds in the ELEVATOR DRIVE SYSTEM 4 The input to LOGIC and CONTROL is not correct. 5 The FLAT CABLE is damaged. 6 Circuit for the ELEVATOR STEPPER MOTOR is not operating.
Nov 20, 2013 | Kodak Digimaster Ex110, Same As Canon Ir...
I get a E 7 system error what is this error
test the 2 alternatives for this error 7 .God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Oct 06, 2013 | Matrix Commercial Treadmill: Mx-t5x
My vision treadmill T9800HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7.God bless you
2)Alternative:
Sep 20, 2013 | Vision Fitness 2011 Vision T9800 Hrt...
My vision treadmill T9800 HRT when start shows speed stall and error 7
please see the 2 alternatives for error 7. God bless you
2)Alternative:
Endurance xt3300
follow the steps and fix it. God bless you. You have 2 alternatives with this error.
2)Alternative:
Jun 19, 2013 | Exercise & Fitness
Treadmill Protec Forerunner 3000 E 7 light on (mother control board FH-3545C-E, VER:B2)
Step 1:
you will have two alternatives:
ERROR CODE # 7
2)Alternative:
see the block diagram+additional diagrams for troubleshooting and fix it.
God bless you
Step 2:
1_4_2013_6_15_26_pm.jpgelevation motor diagram
Step 3:
treadmill motor control board diagram
Jan 04, 2013 | Sportcraft Exercise & Fitness
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
E7 error message
see this steps and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 27, 2012 | Exercise & Fitness
I have a Sole F63 treadmill and it came up with an elevation error. When I switch the unit on, there is a motor running and "Elevation Error, Press Stop to Bypass" is displayed on the screen. How...
Test the flexible cable from keypanel vs display board and tigh the connector from display board vs main controll motor board. Test the relais if there are. Test for open and close, and clean the contact with spray for clean contact. Watch the videos. Finally the display board can be faulty b) main motor board too faulty.
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedgood luck , sincerely God bless you.
E.CUADRA
MANAGUA, NICARAGUA
Sep 24, 2011 | Sole Fitness F63 Treadmill
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Startrac Fitness Products Star Trac Pro S Treadmill Logo
392 people viewed this question
Top Startrac Fitness Products Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Techmotionusa.com
Techmotionusa.com
Sportsmith LLC
Sportsmith LLC
Are you a Startrac Fitness Products Exercise and Fitnes Expert? Answer questions, earn points and help others
