Question about Panasonic DBVSQ-W0044 Remote Control
I have an accutune dvd dmr-ez17 super multi format recorder. my remote stop working the unit.it is the one that came with the panasonic. When I press any control on the remote the unit shows rc 1. What can i do to reset remote ?
SOURCE: Panasonic DVD Recorder DMR EX95VEBS remote control only displays DVD3 how can I reset this to get back to proper functions?
Dear FixYa
Thank you for your support. I have solved the problem on my DVD Recorder by reading other peoples solutions to this problem. My DVD display was showing DVD3 and all buttons would not work. So on the handset I pressed the ENTER/OK button and no. 3 button together for a few seconds, this cleared DVD3. I was so pleased that this worked. croneruk, 6/10/2008
Posted on Oct 06, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
nandosnut
  • 112 Answers
SOURCE: Panasonic DVD Recorder DMR-ES10 Remote Control
Your player and recorder are, most likely, on different codes. Press and hold ENTER and 2 on the remote for at least two seconds and you should be home and dry!
Posted on Apr 18, 2009
SOURCE: panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Posted on Jul 01, 2009
ravichetty
  • 158 Answers
SOURCE: Error message "remote dvd 3"
PRESS 3 AND ENTER ON YOUR REMOTE OR VICE VERSA
Posted on Aug 03, 2009
My Panasonic DMR-EZ17 DVD Recorder keeps saying
You have to use the remote for this unit or a remote for a similar dvd recorder, when you have it hold the enter/ok button and the number 1 or which ever number your stuck on 2 or 3 for 5 second and then go into setup and change it to the one you want RC1 ,2 or 3 !
Jun 26, 2010 | Panasonic DMR-EZ17 DVD Recorder
How to convert my Panasonic DMR -E30 dvd recorder from uk region to multi region format
Turn On player with no disc inserted
While pressing Shift on the remote press Setup
Press Enter twice
Move the cursor to Other
Enter the appropriate four-digit region setting, beginning with 000
Press Enter
Press Return twice
Switch unit Off for at least 3 seconds
and here are some other HACKS for your players
like Macrovision bypass ISCSI BAYPASS ETC
http://www.videohelp.com/dvdhacks/panasonic-dmr-e30/1585
Jan 17, 2008 | Panasonic DMR-E30 DVD Recorder
Display says nodisk and won't open tried troubleshooting suggestions
TRY Press and hold PLAY AND REC both buttons for about 5 seconds To restore the unit if it freezes...
Jan 04, 2010 | Panasonic DMR-EZ17 DVD Recorder
"No Read" display...99% of the times.
OK. Since the laser cleaning disk could not be read I used a can of air (used for air brushing) and blew air into the disk opening. I thought I might clean any dust that may have collected around any parts that needed to be cleaned. This seemed to have worked. It is also possible that dust accumulated in an area that would not allow the disk to line up properly. This could explain why it worked sometimes. If this continues as a problem I will use the EZ17 only as a tuner for my EZ55.
Oct 01, 2009 | Panasonic DMR-E55 DVD Recorder
Any1 know how to unlock Panasonic DMR-EX768EB to multi region??
Hi
Get an unlock device DMR-EX768 (never mind the EB) from www.genuinecopies and follow the instructions. On the handset the red square in the bottom row is the STOP/EJECT
Mark
Feb 14, 2009 | Onkyo DV-CP704 DVD Player
Panasonic DMR ES15
Got me too... If the buttons on the main unit work normally, then possibly main unit and remote control are using different codes. Main unit shows SET 1; change remote control code to match it: Press and hold [ENTER] and code number [1] keys for more than two seconds. Fix listed in Operating Instructions troubleshooting guide, Operation section (pg 42). MULTI.PDF">http://service.us.panasonic.com/OPERMANPDF/DMRES15-MULTI.PDF
Apr 30, 2008 | Panasonic DMR-ES10 DVD Recorder
HELP
"To fix the problem that your having with the remote press the number 1 & enter on the remote at the same time for 7 seconds."
Apr 20, 2008 | Panasonic DMR-EZ17 DVD Recorder
Recording
your blank dvd might be the wrong speed for that dvdr
Oct 30, 2007 | Panasonic DMR-EZ17 DVD Recorder
Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Aug 15, 2007 | Panasonic DMR-EZ17 DVD Recorder
No picture
[I am assuming that the recorded disc was not made using the DVD recorder]. It's most likely that the video portion of the file is encoded in a format that is not supported by the DVD recorder. The player only supports DivX, JPEG, and MP3 formats. So try transferring the file on the disc to a computer and encoding in a supported format. You can use free online services such as http://media-convert.com/ or http://www.zamzar.com/ to encode media files into different formats.
Jul 29, 2007 | Panasonic DMR-EZ17 DVD Recorder
Panasonic DBVSQ-W0044 Remote Control Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
