Question about Cameras
I used a 4 GB Duracell SD Memory Card in my Canon digital camera. The card now says there's an error and that it is locked. The little switch on the side is "unlocked" but still says locked in the camera. Please help to unlock it. Thanks.
  • 643 Answers
Sounds like the memory card needs to be reformatted. you would need to put it in a laptop or desktop and reformat the memory chip that way.
Posted on Nov 09, 2010
Memory card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 10, 2014 | Canon PowerShot SX 200 IS Digital Camera
I have a memory card error on my canon powershot SD 1200 IS. It says " memory card is locked. How do I fix it ?
Your memory card is an SD type. These cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
Nov 03, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Memory card error Canon Power Shot sx100
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Oct 22, 2010 | Canon PowerShot SX100 IS Digital Camera
I got a new 4gb sd memcard for my 2005 canon ixus 50, screen shows " memory card error" "card locked". tried switch on card as u suggested, no diff.
The IXUS 50 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards 2GB and smaller.
Oct 06, 2010 | Canon Cameras
I buy a memorycard sandisk 4 gb, i have a photocamera canon ixus digital 750. i insert memory card into my camera and than it show me : "errore memory card, scheda bloccata ". what must i do ? thank you
Hi
Make sure that the card is not write-protected (the little switch where it is written LOCK) and do not forget to format the card via the camera menu.
If you did everything as described and it has not helped change the SD card, it is likely damaged
Aug 19, 2010 | Computers & Internet
Is canon digital IXUS 55 compatible with 4gb SDHC memory card message reads card locked or error
The maximum amount the Canon sd450 can support is a 2gb card, anything more and you 'll just get error problems.
Aug 16, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
I just bought a 4 GB SDHC card so I can take longer videos on my canon A610. I can't get it to work, even though i formatted it using my computer reader. I spoke with the card maker, and they say that they...
Your camera, introduced in 2006, cannot use SDHC cards, but only 'standard' SD cards up to 2 GB.
You should always format the cards (if needed) in the camera and not in the computer to ensure compability.
Aug 06, 2010 | Canon PowerShot A610 Digital Camera
Memory Card Error on my Canon Power Shot S2 15 using Kodak SD car
Hello
Kind regards
Andrea
Jan 27, 2009 | Kodak EasyShare C315 Digital Camera
Sandisk memory card
Has this card EVER worked with your camera? Since you didn't mention the model number of the Canon, it's possible that you have a compatiblity issue here. Most 4GB SD cards these days are actually SDHC cards, which store memory differently (in sectors, like a hard disc drive, rather than bytes, like your main memory). All SDHC compatible cameras also support SD cards, but cameras sold before the SDHC standard was created will not support SDHC memory cards.
There's a chance that Canon has a firmware upgrade to solve this. You would have to look on the Canon USA web site for this, based on the model number of your camera.
Jan 20, 2008 | Cameras
Cameras Logo
131 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
