Question about Dell Computers & Internet
Dell Desktop Will not power up. Orange flashing light when power button is pushed.
  • 2 more comments
  • jdbarlow Jun 16, 2008
    Yes
    Dimension E510 ,Intel Pentium D Processor 820 with Dual Core Technology (2.8 GHz).
    Does not boot at all.
    John
  • wedding546 Jan 31, 2009
    Will not power up, just a flashing orange light. Once in awhile I can get it to power up but then if the power goes out or it is turned off it won't turn back on.... But It seems like it is the power button because this happens after the computer is moved or something.
  • Anonymous Mar 13, 2009
    Will not turn on, power button flashes orange. It's been acting strange for a while, and I have tried not to shut it off because one of these days I know it just wont turn on again, and today is that day!
    It would turn on if I held the power button pushed into the on position, but it wont even do that anymore. I only shut it down last night by accident. UGH.
  • Anonymous Apr 08, 2009
    Having the same sort of problem, leave the computer on or playing a game or something and it just turns off and the power light flashes orange, it wont let me turn my computer on again for about 6 hours (have to take the power cable out the back for the light to go first) but i also get PCI device not connected or something like that sometimes, i've taken my Dimension 5000 back and they said it was a memory problem and replaced it, but now its starting to happen again, from what i've read on dells the motherboard seems to be the problem some sort of corrotion in the board or somthing like that, take the side off and have a look and you might see something on the board then call dell for a replacement if it is that.
Unplug the power supply hold the power supply button down with the cord out for up to 60 seconds, then plug it back it, worked for me.
mine was caused by a sensor program trying to access the sensors in the PC which caused a boot failure for some reason.
(computer shutting down to protect itself?)
Posted on Nov 25, 2008
  • 78 Answers
Have you tired holding down the power button. Other wise what model is this computer? And how far into the boot cycle does it get?
Posted on Jun 16, 2008
  • Rhys Parker Jun 16, 2008
    OK, sounds like a hardware fault, Unfortunately you will have to take this to a tech.
    Sounds like a blown motherboard or power supply unit.
    Are you getting any error?
3 Suggested Answers
JUGGALOTUS
  • 151 Answers
SOURCE: on my dell dimension desktop the power light is flashing orange
Check all connections on the computer outside and inside, re-seating ram sticks too, if that dont work you might need a new power supply.
Posted on Oct 18, 2009
  • 83 Answers
SOURCE: Dell Dimension 9150, flashing orange light on
The power supply needs to be replaced, How old is the system, Can you provide the tag, i may be able to get you one for little or no cost. if your interested :)
Stephen.cscorp@gmail.com
Posted on Apr 14, 2010
Dell optiplex 360 power button orange light
is the orange light flashing? if it is, that would indicate a problem with your power supply or wall outlet to your computer.
Jan 21, 2014 | Dell Systems Dell OptiPlex 360 Minitower...
I have a dell optiplex 745 and the light on the power button flashes orange when power is connected
IS YOU SURE IT'S THE POWERBUTTUN.AND NOT THE HDD BUTTON .IT SHOULD FLASH WHEN THE COMPUTER READ.?
Apr 04, 2013 | Dell OPTIPLEX 745 PC Desktop
Dell GX280 orange light on MOBO
Dell Support > Optiplex GX280 Desktop PC > User Manual,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tindex.htm
I chose the Mini-Tower model because the following information applies to all models;
Small Form Factor (SFF)
Small Desktop
Desktop
Small Mini-Tower
Mini-Tower
Computer and Software Problems > Troubleshooting Tools and Utilities > System Lights,
http://support.dell.com/support/edocs/systems/opgx280/en/ug/tools02.htm#wp1114432
Now scroll down. What do the Diagnostic Lights indicate?
Post back in a Comment.
Regards,
joecoolvette
Oct 09, 2012 | Dell OptiPlex GX280 PC Desktop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Orange flashing light on a dell dimenson 5150 computer won't start up
The orange flashing light on the power button is an indication of power supply failure.
Your Power supply unit needs to be replaced.
Aug 11, 2010 | Dell Dimension E510 Dual Core 2.8 Ghz...
Power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
Jul 06, 2010 | Dell Dimension E310 PC Desktop
I get orange light on my power button when i power my dell optiplex 330 pc
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber, bad power supply
Solid Amber either a bad component connected to motherboard of the motherboard itself has failed
Jun 23, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Flashing orange light on power button of Dell Dimension 5150 ...
If you experience the dreaded blinking orange power light, make sure to check your motherboard for blown capacitors as well as corrosion on the motherboard. Looks like the photo below.... if you see this then a replacement motherboard is needed.
Aug 04, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computers & Internet Logo
2,072 people viewed this question
Alun Cox
