Question about Bose LIFESTYLE VS1 Lifestyle174; VS-1 Video Expander System
Continuing from last night
I looked for HDMI cables this morning to see if it was the cable that was bad, but every cable was near $100.00. Can we start at another point? I should point out that one month ago, I had Geek Sqaud come out and reconnect everything. It has been working beautifully unitl yesterday. No one has touched a cable. Thanks.
  • 4,472 Answers
First thing you might want to try is hooking up the lifestyle directly to the tv without the vs-2. So we can eliminate that as a problem. I assume everything is going to that. There are some issues with these systems it seems but lets see if we can work it out though.
Keep me posted,
Lee
Posted on Jun 16, 2008
  • Lee A.
    Lee A. Jun 16, 2008
    Someone else had the same 4 blink problem and did this to replace it: It is 2 faulty IC's MCZ3001D IC. they cost 5.50 each on the D board. They can be soldered in.
    Thats should be your problem. Each blink leads you to which IC is the problem.
    Hope that will be what you need,
    Lee
  • Lee A.
    Lee A. Jun 17, 2008
    Did this help you at all?
    Lee
My tv is brand new. Last night it did not turn on right away and said that my tv does not support this programs content protection and to replace the HDMI chord to component cables
I've seen this before, its usually a cheap or bad HDMI cable, try unplugging both ends and plug back in and then turn everything back on and see if that solves it. If not go get a new HDMI cable and try that.
Sep 19, 2017 | Televison & Video
HDMI NOT WORKING
A power surge? This could do a lot of damage to everything.
Apr 07, 2017 | Televison & Video
2001 chevy impala wont start just make a click sound started fine last night this morning nothing pls help its not the security thing either had that fix on the recall
Before you trouble shoot a car always charge your battery. It sounds like you have a loose Battery Cable to the Starter to me. This has happen to me that's how I know. To confirm this pull on the positive battery cable while someone else tries to start your car. Did it start? If it did not start then it's between your Battery and your Starter. Let's now check your Battery. Fully charge it again and make sure you have 12.6 Volts if your Battery does not take a charge it has a bad cell and needs changing. If your Battery turns out good then you have to check your starter or Solenoid and if one is bad change them both. Remove it and have an auto store check it to see which one is bad. I hope this helps you out. Let me know how you make out.
Jan 09, 2015 | Cars & Trucks
I just bought my 42in last night and I attached my cable box to it, with a normal black coaxal cable and the red/white/yellow hookups. The only problem i have is the picture looks kind of grainy and...
Cable box have HDMI port,hook it up on a HDMI cable to the tv,will improve picture quality greatly.Tries HDMI cable to hook up the PS3 system and go in setup changes to HDMI setup will get HD format picture,will be very clear no more grainy and inconsistanty.
Feb 17, 2011 | Sansui HDLCD-4212 LCD TV
Great picture but suddenly no sound over HDMI cable
try replacing hdmi cable. if that doesn't work you have something in the amplifier curcuit bad
May 15, 2010 | Televison & Video
I am having connection issues with an LG 55lh40 television, a HD DVR from Directv, a PS3 and a DVD/VCR combo. The TV seems to be working good, but does not seem to be picking up an HDMI cable of any kind....
No picture
when connecting HDMI:
Check HDMI cable over version 1.3.
The HDMI cables don’t support HDMI version 1.3, it cause flickers or no screen
display. In this case use the latest cables that support HDMI version 1.3.
Feb 14, 2010 | Televison & Video
Television is not recognizing HDMI inputs
there is a possibility that there might have been a power surge sent over hdmi into the hdmi board on the tv. if on your model the hdmi board is seperate from the sine board then youll have a cheap replacement if not its gonna cost you roughly 300-400 is my guess.
call your repair guy
Aug 02, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No picture no sound
If you are using HDMI sometimes an improper shutdown will cause the HDMI "Handshake" to get confused.Try going to the Crossbar (Menu) on the PS3 2nd coluom from the left and down to Display Settings. Choose the appropiate output settings and use AUTOMATIC whenever possible. After that Set your Audio again use AUTO. Never plug in HDMI cables when Power is on it can and will short out that Input!! Good Luck!
Apr 26, 2009 | Sony PlayStation® 3 (80GB) Console
No sound from speakers after connecting to pioneer a/v vsx81
I had the same problem and resolved it last night. You'll also need to connect an audio cable (EVENTHOUGH YOU SHOULDN'T HAVE TO - to bad pioneer didn't fully implement the HDMI standard in this receiver) solution. I suggest using an Optical cable. This really annoyed me...see the manual on P.17 section #3.
Dec 28, 2008 | Pioneer VSX-818V-K Receiver
62 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
