Question about RCA RTD207 System
The CD/DVD door will not open, everthing else works fine.
  • RCA Master
  • 13,433 Answers
There are many possible reasons for why the drive won't open.
1. the drive mechanism is stuck.
2. the motor that moves the tray is broken
3. the flat cable that transfers movement from the motor to the other gears is out of place
I'll stop there, If you are outside of warranty, you may take apart the dvd player, if you are in warranty, then just try unplugging the dvd player for 5 minutes and then try again.
If your outside of warranty and your prepared to take it apart, unplug all the cables and unscrew the screws to get the top off.
Inspect the drive, and try to help it eject by rotating the gears in the drive, they might be a bit difficult to move as they may be hidden under the tray, find a way.
Once you get the tray to release the problem might be solved, inspect the gears and the rubber transfer cable from the top of the motor to the other gears that it in place and moves freely.
Put the power back on, don't touch anything inside the player while its plugged in. Now, see if the ejecting and inserting of a disc works properly. If it does, unplug and reassemble the unit, the problem is solved.
Posted on Nov 09, 2010
  • Ekse Nov 09, 2010
    on 3. I said Flat cable What I meant is a small Rubber belt. the belt can also be worn out, too loose, or broken / out of place.
  • zinda Jan 25, 2011
    i had this problem when I bought a used unit and what I did was removed cover as stated above and while I pushed the eject button I looked to see what was moving and what was not moving. I looked to see what was needed to eject the dvd trays and saw that the motor that drives the entire system would start briefly then stop before anything could get engaged to start the ejection process. I just took my finger on the dvd that was in the playing position and while pressing eject I spun it and after the eject process got started I stopped spinning it and it carried on without help. I did leave the cover off and turned off and on then ejected again and noticed that the disk did slow down and stop before it ejected and thought I would need to spin it again but it started spinning and worked on it's own. From then on it has worked fine. But I need a manual for the thing! If you have one please email a copy zinda@cox.net I would be so happy since I didn't get the remote for it I've been trying to figure out how to get the DVD's to play all tracks without having to press the cursor down to the next after each video. I'm thinking I'm lacking a button on my universal remote for this function or maybe it just won't do it at all?
Dell cd drive door won't open
CD/DVD Drive Tray problems
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
Feb 22, 2013 | Dell Studio XPS 8000 (DXCWKW12) PC Desktop
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
I have the DZ-GX5020A DVD Cam....the disc eject door will not open.....I can hear it clicking trying to open, but no luck... everthing else works fine.......can you help me?
None of those options worked for me. I had to remove the single screw on top of the camera. Then slide the silver top panel forward to remove it. Then remove the dark panel where the screw was removed. Then you should see a small metal piece very close to the DVD door opening that is holding it closed. Slowly nudge it forward to unlatch the door. This allowed me to open the door to remove the DVD. Unfortunately I still have to do this every time to get the door open. I may try some lubricant on the metal to prevent sticking.
Jul 02, 2010 | Hitachi DZ-HS300A DVD Camcorder
DVD Rom door will not open
Take a paperclip and unbend it into a straight line. There should be a small pin hole on the face on the DVD ROM drive. Poke the paper clip into this hole and it is the release button to open the drive. Works great when you have powered off your computer and want to get the CD/DVD out without powering back on!
Jan 07, 2010 | HP DVD DRIVE DVD Drive
Yamaha dvd player S530 disc tray no open, Outer player shell is off and no dvd nor broken parts, cannot find a manual release button? is their a remedy or a service manual for this.
I downloaded a service manual for this unit. It showed where the manual release mechanism was. Released the cd stray, examamined the mechanism and found nothing. Added a little lubrication to some of the moving parts. Reassembled, and everthing now working fine.
Dec 15, 2009 | Yamaha DVD-S530 DVD Player
Will Not reconise Cd or DVD in the Drive
Yes, this drive is basically dead. You can find pretty cheap prices for new drives at www.pricewatch.com
If the drive door closes on a cd or dvd that you want and it will not open back up, use a straightened paperclip and push it into the little hole near the door on the drive, the door will pop open then.
Mar 29, 2009 | Sony DW-G120A DVD RW Dual Layer Burner
Hello please help me
Your lens is out of adjustment. Cleaning sometimes work. They aren't hard to open and realign...happens over time
Oct 09, 2008 | Clarion VRX935VD Car DVD Player
DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Aug 28, 2008 | Audio Players & Recorders
You should make sure that DVD lance is power. You can check the lance by switch on the door switch.
May 11, 2008 | Sony SLV-D350P DVD Player/VCR
CD/DVD
see care fully on the cd/dvd door, there must be a very narrow hole. This is an emergency hole to open the door.
  1. Make shutdown your Lap.
  2. Take a long niddle or hard wire.
  3. Push it gently inside the hole.
  4. It will strick inside, then push with slightly more force and you will notice that door is openning. Just push more till you can pull out CD/DVD tray by hand.
Thanks
Iqbal
Apr 28, 2008 | Dell Open Box 8300-6SZ0X41 P4-2.8G 256M...
RCA RTD207 System Logo
177 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
