Question about Electrical Supplies
I have a Winco PSS12H propane fueled standby generator. The propane delivery system consists of a regulator on the propane tank and a 50+ foot run to a low pressure regulator that is then connected to a demand regulator inside the generator. My problem is that the unit does not start reliably. The service techs have replaced both the low pressure and demand regulators, but it still takes 4-5 tries to get it going when the temps are below 60 Degrees. The Winco manual says that the low pressure regulator must be *more* than 10 Feet from the demand regulator, and in my case it is 1 foot away. So my question is, is the length of the tubing between the two regulators that critical, and could that be the cause of my problems?
Ajkill
  • 2035 Answers
SOURCE: 1997 S-10 fuel line/fuel pressure regulator
Please this link :
http://www.autozone.com/addVehicleId,2336303/initialAction,repairGuide/shopping/repairGuide.htm?pageId=0900c152800bfe20
Posted on Jul 08, 2008
burzerko
  • 254 Answers
SOURCE: low flame
This problem most likely is with your regulator. if you decide to replace it please make sure you get the right size replacement. Some salespeople dont know the difference there are four common sizes from class 1 to class 4. If you take the old one with you make sure you match the numbers up with a new one.
Hope this helps You
please rate me.
Posted on Jul 20, 2008
rayname
  • 70 Answers
SOURCE: Goodman GMNT furnace goes into 'lock-out'.
check to see if your intake pipe or vent is clear this could cause a flame jump and make it look like a bad flame sensor let me know if this helps
Posted on Jan 08, 2009
  • 220 Answers
SOURCE: fuel pressure problem.I replaced the fuel pump on 2001 chevy s-10
Most fuel injected vehicles have a relay that controls the fuel pump so after the ignition switch has been on for about 5 seconds and the engine is not running, the fuel pump automatically shuts off.
I don't know what your original problem was, but I think if the car runs normally, you have probably fixed your problem. If you don't have a manual, you can probably go to the library and take a look at a manual that covers your vehicle.
Posted on Jan 16, 2009
gcken
  • 140 Answers
SOURCE: Kenmore Gas Grill 141.155401 issue with Propane tanks
replace the regulator
Posted on Apr 14, 2009
Bought new. No problems until two weeks ago. Now has 252 HRS. Starts all the time, runs 10 seconds then shuts down. I have removed wire an oil pressure switch. no help. Found connector off on switch p
It shuts down because it's not making power. You are probably getting a failure to start error code. If it doesn't make power it doesn
t know its running. Rotor has lost residual magnetism to start the voltage regulator. Replace the voltage regulator. The new one is designed to overcome this.
Dec 10, 2014 | Briggs & Stratton Briggs Stratton 7 kW...
9000kw winco generator
varying load causes varying operation...= normal
i.e: generator reacts via voltage regulator to compensate amp draw.
Mar 01, 2014 | Winco Hps 9000 Ve 8000 Watt Tri Fuel...
Winco PSS8000 Standby Generator won't start
This question is too vague to give you a good answer. But since it's coming up very high on Google searches, and I recently solved the same problem on the same generator, I thought I'd add a few notes here for others.
In my case, the engine would take a lot of cranking before it would start, and eventually refused to start altogether. If your engine won't even crank, ignore the rest of this, you have a different problem (starter, battery, cables, or solenoid).
I'm also going to assume that you've checked easy stuff like the fuel supply, spark plug wires attached, etc. The PSS8000 runs on propane or natural gas. If it's cranking for a while and not starting, you should smell gas (not gasoline, gas like the gas grill before you light it). If not, then you have a fuel problem.
In my case, all the usual stuff was fine but still no start. The problem was: low compression caused by negative valve clearance. Apparently gaseous fuels wear valves and seats faster than gasoline -- as a result the valve clearance (which is supposed to be a small positive amount) is reduced so the valves are basically held open a tiny bit all the time. This causes several nasty problems, but in my case the main one was low compression. As a result of that, the engine had a hard time starting.
So in addition to all of the usual stuff (plugs, spark, fuel, etc.) check your valve clearance -- you're supposed to do it every season anyway. On my engine the correct clearance is 0.004-0.006" for both intake and exhaust.
Feb 10, 2013 | Winco 200-Amp Automatic Transfer Switch -...
I have a Kohler 12 RES home standby generator. Once in a while when the power goes out the generator will start and then immediately shut down with no fault codes. When I flip the control in the unit
Check the inlet fuel pressure, on exervise there is no load, when power is out it is loaded and demands more fuel. Also check for bugs blocking gas regulators vents etc
Nov 12, 2012 | Kohler Generator. 12 kW and 14 kW Home...
Need adjustment procedure for a Generac Centurion generator, carb and regulator under full load
Before you adjust anything, suggest you verify gas line for proper pressure and importantly volume. Pressure for gas should be 5 to 7 inches and propane 11 to 14 inches W.C. Also make sure the line to the generator is sized properly and the gas meter is a high volume unit (if NG). 90% we find the problem with generator sunder load that otherwise are fine are fuel related. Good luck.
Sep 19, 2012 | Generac Power Systems Centurion by 16000...
Winco WC12000HE won't start...fired up last night and I'm getting nothing today.
Sounds like a fuel problem, check your filter if there is one. Check fuel in tank, make sure there isn't a valve off. Check your choke if you have a manual choke.
Sep 28, 2011 | Winco Industrial 10.8kW Portable ...
I have a portercable 5250 generator works great starts great shutts down after about half hour maybe 20 percent load oil good disconnected oil switch, changed feul,carb seems good, bowl clean still...
Seems that you have covered all the bases. The problem that you describe could be related to fuel lock or restriction in the fuel delivery system. Easy to check. Remove the air filter and have carb cleaner ready. If you are near the gen when it begins to quit, spray just a little carb cleaner to see if engine tries to run. If engine begins to run or continues to run with carb cleaner, then suspect fuel delivery problem. If the engine seems to stop quicker with carb cleaner, suspect flooding caused by too much fuel pressure (fuel pushed past the needle due to pressure in the tank; open fuel cap and listen for air pressure release). Fuel delivery problems are caused by collapsed fuel line, restriction in the fuel cut-off valve, restriction at the fuel filter (use larger automotive type), negative pressure in tank caused by no vent at cap. Rare problem with fuel delivery is caused by sudden heat rise at the carb causing fuel to boil out of carb. This is caused by the engine running very hot, lack of air across cooling ribs caused by debris or fan missing blades. You can eliminate the complete fuel delivery system by mounting a small fuel tank on a stand and running fuel line directly to the carb for test. The tank needs to be higher than the carb so that you will have good gravity feed. Good luck
Aug 30, 2011 | Porter Cable PorterCable BSI525W 5250 Watt...
My generator is a briggs and stratton 7kw prowered. connected to full propane tanks. i have not had any problems with the generator until this past weekend. the generator starts up fine, and then once...
You have a fuel delivery issue that can be dealt with by cleaning carb or replacing it. If you do replace carb has to be adjusted to the motor.(idle, mixture)
Sep 03, 2017 | Briggs & Stratton Briggs Stratton 7 kW...
My gas furnace fires but then cuts out. There is a similar post on here about this but my problem is a little diiferent. The unit kicks on, fires then shuts right down. The blower comes on and stays on....
HAD A similiar problem last week with a customer who had just installed a pool and running off of propane tank for gouse as well... he let tank go empty and started having problems ..what we ended up finding is that not only was his regulator on tank bad he needed a additional regulator to regulate the different psi pressure to the appliances... get them to check your regulator out
Jan 24, 2011 | Goodman Heating & Cooling
Briggs and Stratton propane gernerator will not run.
The engine is starved for fuel. Check fuel flow. Possibly a dirty fuel filter someplace in the line or the regulator has low flow.
You can verify this by putting an UNLIGHTED Bernz propane torch into the intake. If that improves it, then low fuel flow is the culprit.
Fuel filters for propane are very fine and can plug up easily. I am not sure where yours are, however I would check at the inout of the regulator for one there for sure.
Mar 31, 2010 | Briggs & Stratton Automatic Home Standby...
Electrical Supplies Logo
60 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
